What should i do?
Old Apr 4, 2007 | 12:50 PM
I6power's Avatar
I6power
What should i do?
So ive got this vehicle thats been sitting for a while. It cant be driven at the moment cause its in the process of getting new brake lines. I still like to periodically run it to keep the fluids moving. There is one problem though.
The transmission has a leak. Shes got a bad leak. My haynes manual says that to get an accurate reading the vehicle should be driven for a while before the transmission fluid level is checked. I obviously cant do that (no brakes). I dont want to run it in idle and then check the fluid because i dont know how much life is left in this transmission. When i do run the car to keep the fluids goin the tranny smokes. I assume thats not good.
What do you think i should do? This vehicle is a 1970 Firebird with a TH350. I know this is a ford sight yadda yadda but i need help and from my experience so far the ford boys know best. All the pontiac forums blow. Any help is appreciated.
Old Apr 4, 2007 | 01:11 PM
WarWagon's Avatar
WarWagon
Check the fluid as the car sits. It will read up to an inch higher than when it is running. If it has enough fluid, then start it up and find out whee this bad leak is coming from, then let me know.
