86 150 oil leak
Old 04-02-2007, 09:05 AM
86OldBlue's Avatar
86OldBlue
86OldBlue is offline
86 150 oil leak
I have an 86 f150 with a 302 EFI and 3 spd. OD. It has been leaking oil for quite some time now but i am not sure where it coming from. I have replaced the valve cover gaskets, rear main oil seal, and the front timing cover oil seal. Is it possible for it to be leaking from the intake manifold end seals. Thanks for any help.
Old 04-02-2007, 09:36 AM
reamer's Avatar
reamer
reamer is offline
You Bet! On my '86 EFI 302, the rear gasket on the lower intake had a curve in the gasket material. The problem was the block and intake mating surfaces are straight.
A gasket with a curve in it, and a straight lip on the casting = oil leak.
Reamer
mtflat's Avatar
mtflat
mtflat is online now
Yes, if someone didn't pay attention when they put the intake on, it can leak. IMO Ford used a crappy 4 piece gasket set that seals the intake - lots of possibilities for water and oil leaks. If it's leaking out the back, it's probably the 's' shaped seal on the back edge of the block.
Old 04-02-2007, 12:11 PM
86OldBlue's Avatar
86OldBlue
I thought that it might be what was leaking because I have antifrezze leaking from about the same area. Oil and antifrezze runs down the right side of the engine and drips on the exhuast pipe crosses over. It burns off and smells really bad through my heater/defroster.
Old 04-03-2007, 08:11 PM
locknkey's Avatar
locknkey
locknkey is offline
That sounds like a head gasket....leaking antifreeze.
Old 04-03-2007, 09:00 PM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,654 Likes on 1,337 Posts
There are water passages near the end of the intake manifold too. The best tip I ever got was to use the side gaskets, but throw away the end gaskets and use a thick bead of silicone instead.
Old 04-03-2007, 09:26 PM
paulcooper1969's Avatar
paulcooper1969
paulcooper1969 is offline
I agree with Dave I have had a few 302's and used the gaskets that came with the set and it seemed to always leak from the back gasket, after replacing my share of them I was told from a Ford GURU throw the end gaskets away and use a thick beed of RTV black, do not use blue,red, nothing but RTV black lay the beed on the block and set the intake down on there, its a one time shot deal, if it moves the slightist little bit, start over. I have had great luck with all the ford motors I've built since then using this method.
dudef150
11-04-2014 12:45 AM
bigcrunch
03-24-2014 08:10 AM
riverratba
2004 - 2008 F150
11-24-2012 06:36 PM
IreallyLikeFords
01-21-2009 08:49 PM
Dustin_86
09-03-2006 05:49 PM
Quick Reply: 86 150 oil leak
