Removing That Stupid Clip On Wastegate?
I stayed under the hood for God knows how long trying to remove the clip on the wastegate. (I want to remove it to tighten the rod) I was using one of those clip removing tools that loks like screw driver shaft with the tip bent over at a 90 deg angle. Since I had no luck with that tool, I am going to try something else. Any suggestions?
This thread has some tips, and my post has the part number that hambonz mentioned:
https://www.ford-trucks.com/forums/4...p-removal.html
I didn't have a pick or anything, so I bent a nail at a 90* angle and gripped it with a pair of vice grips.
I put a clip exactly like NAPA part number BK 7352640 on my WG rod. I'm not sure if this part number is the right size or not. I fished mine out of a box of goodies that were laying around the shop. But it looks exactly like the one in the picture and it's very easy to take off and reinstall without losing it. (The clip or your temper. ) It's a sort of little retainer clip that holds itself down over the end of the post.
To remove the clip all you have to do is lift the little clip and slide it backward a bit and it releases. And it does not come off unless you take it off.
http://www.napaonline.com/MasterPage...e+Linkage+Clip
88_F0RD
05-11-2016 09:19 PM
Blowinsmoke
09-27-2009 05:18 PM
