vege oil
Old 03-20-2007, 03:38 PM
dwags15's Avatar
dwags15
dwags15 is offline
vege oil
anybody out thetre burning vege oil for fuel.??
Old 03-20-2007, 03:47 PM
adambomb's Avatar
adambomb
adambomb is offline
not in my powerstrokes, for them i use biodiesel. but i do run 100% veggie oil in my converted 83 mercedes 300td.
Old 03-20-2007, 05:59 PM
firemediceric's Avatar
firemediceric
firemediceric is offline
I run a single tank WVO blend in my '83 Mercedes and '99 F-350
Old 03-22-2007, 03:36 PM
davE350's Avatar
davE350
davE350 is offline
What kind of blend?
Old 03-22-2007, 03:39 PM
davE350's Avatar
davE350
davE350 is offline
What system are you using for the veggie oil? Do you make your own biodiesel?
Old 03-22-2007, 07:47 PM
firemediceric
Originally Posted by davE350
What kind of blend?
Waste Veg Oil with 20% Kerosene and 5% Gasoline along with a dose of Diesel Kleen Power Service and a couple ounces of Xylol and Naptha per 40 Gallons. For me, it gets the viscosity right, I don't deal with the chemicals required for Bio-Diesel and I don't have to do mods on the truck or car to run it.
Old 03-22-2007, 08:01 PM
adambomb's Avatar
adambomb
adambomb is offline
davE350
my mercedes has a basic single tank lovecraft veggie oil conversion. it can run on veggie oil, biodiesel, diesel, or any combo of the 3. i have made test batches of bio before but now get commercial bio from a distributor delivered to my house.
Old 03-23-2007, 08:57 AM
davE350's Avatar
davE350
davE350 is offline
Thanks, Lovecraft veggie oil conversion? I will have to do a google on that.
Is there a forum on FTE where I can find out about the different systems guys are using for WVO?
I've been on to many of the grease conversion sites. They all talk like it's the only game in town!
Old 03-23-2007, 11:10 AM
adambomb's Avatar
adambomb
adambomb is offline
lovecrafts site is, lovecraftbiofuels.com. I am waiting to see how the veggie conversion goes in my old mercedes before i do it to my F350. They were converting a F250 w/ 7.3l when I was in there. So far it's been going very well, besides the expected plugging fuel filters. There system is very basic, it uses the stock fuel tank and adds a booster fuel pump, heat exchanger, heated fuel filter bowl, and they change out your fuel lines to veggie resistant sysnthetic rubber.
Check out the Bio Diesel/ Alternative Fuels Fourm just a couple clicks down from this one . That forum has tons of great information and some very knowledgeable and experienced posters.
Old 03-23-2007, 01:41 PM
davE350's Avatar
davE350
davE350 is offline
I did a google on the site, thanks for the address, it's unfortunate that they are located a two or three drive from me.
I will scan through the Bio diesel treads more carefully. Thanks for your replies.
Old 03-23-2007, 02:38 PM
firemediceric
Lovecraft is not well thought of for Mercedes:
http://www.mercedesshop.com/shopforu...ight=Lovecraft
If you do a search on that site that I put the link up for you will see that there is no end to the negative comments about Lovecrap.
Here is another recent discussion about pros and cons of which way to go:
I could link you to pages and pages of just links. It is generally agreed that one of the most important things about running a veg based fuel is getting the viscosity right. By doing so it places less strain on the pumps and flow/atomizes correctly through the injectors.
There are three basic ways to adjust viscosity. Cause a chemical reaction as is the case with biodiesel, heat the straight veg oil and the heat will thin it out, or blend the veg oil with a thinner to lower the viscosity.
I choose the latter. With relying on heat to thin the WVO, a single tank system is not practical. There is no way you will have the oil at 160* at start up. The engine will have to be running for at least 5-10 minutes or more to get up to 160*. During that time the WVO is not your vehicles friend. By thinning my fuel is already at a lower viscosity when cold.
I could go on all day. In short, it works for me. I'm tired of typing but if you would like feel free to PM me and I'll send you my telephone number. Don't worry, I'm not selling anything.
Old 03-23-2007, 04:31 PM
adambomb's Avatar
adambomb
adambomb is offline
just to let you know i wasn't trying to say what i have is good, i was just responding to the thread and saying what i have. I think a 2 tank system is better because you can purge the system, and have diesel or biodiesel to use at start up. I went with my single tank conversion because it seems very basic and easy to use. Maybe im lucky because I live in Southern California so it doesn't get that cold.
Old 03-23-2007, 05:36 PM
Kwikkordead's Avatar
Kwikkordead
Kwikkordead is offline
Thread moved.
This thread is better off in the Bio/Alternative fuel section.
Old 03-23-2007, 07:09 PM
tdister's Avatar
tdister
tdister is offline
I've got the Greasecar kit on my Rabbit. Haven't had a problem yet...
I start it on ~9:1 diesel:veg oil, then run straight veg after it warms up, once in a while I get a tank of b100. I'd run b100 for start up more often, but it isn't available close enough to me.
Old 03-23-2007, 07:32 PM
bio-d's Avatar
bio-d
bio-d is offline
Plant Drive kit in 87 f250
I have a Plant Drive kit in my 87 f250. Components: Hot Fox pickup tube in auxillary tank, Vormax water separator/ filter unit, Hot Plate heat exchanger, Vegtherm 30A electric heater. Everything works great, even in 20 degree winter driving. Check out www.Plantdrive.com.
Mike
Quick Reply: vege oil
