I have to replace my clutch on my 60. I believe it has the t-98 4 speed tranny. I heard that I can remove the shifter from the tranny housing. If that is true, how do I do that? Thanks
The cap unscrews, then the lever can come out. Why are you removing the lever??
I am replacing the clutch & it just seemed easier not to have that long old handle in the way. It sounds like you have removed clutches and tranny's and not removed the shifter. Is that correct?
