COP's replaced now ERROR CODES! HELP
ok, just got the COP's and plugs replaced, and I wanted to test the response, so I floored it from a take off, SES light comes on, I get home put my OBDII reader on it, and it pulls the following codes:
0182
07E5
0530
Now at first it did 0174, and 017something, now it is only giving me the other codes.
This is the code reader I have, and I can't find my manual for it.
Could it be that the computer just got used to it running one way with the bad COP(s) and needs to be reset?
It seems to be running fine even though I have the SES light on.
0182
07E5
0530
I had the same problem when I did mine. The PO174 is a lean on bank 1 or 2, I don't remember. Check your vacuum lines. I pulled the PCV out completly when I did mine. Fixed the vacuum leak and no problems. I have the same code reader also. Not the greatest but it will pull the codes. You get what you pay for. Check your vacuum lines.
TomFL
03-22-2014 04:42 PM
RetroActv
1997-2006 Expedition & Navigator
07-12-2012 01:30 PM
UncleRedBuck
Modular V8 (4.6L, 5.4L)
11-05-2007 04:04 PM
