1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
What do these fuse do? 1999 F350 7.3
Old 03-28-2007, 05:18 PM
DNJSDAD's Avatar
DNJSDAD
DNJSDAD is offline
What do fuse 15 inside the truck and fuse 29 outside do? I think these maybe my problem but without a manual I have no clue. Thanks.
Dnjsdad
Jason
Old 03-28-2007, 05:26 PM
Beerstalker's Avatar
Beerstalker
Beerstalker is offline
Old 03-28-2007, 05:32 PM
DNJSDAD's Avatar
DNJSDAD
DNJSDAD is offline
29 is my Radio, does it make sense that this would draw enough current to drain the batts? And 5 is the gem unit, i was told that this would draw a minimal amount of power, is this correct? Thanks for the help.
Dnjsdad
Jason
Old 03-28-2007, 05:36 PM
blackhat620's Avatar
blackhat620
blackhat620 is offline
DNJSDAD,
Pasenger compartment fuse panel - Fuse #15 (5A):
Generic Electronic Module (GEM), Powertrain Control Module (PCM), Anti-lock Brake System (ABS) Module, Brake Shift Interlock, Speed Control; page 148 manual.
Power Distribution Box (under hood) Fuse #29 (30Amp): Radio; page 152 manual.
Go here
http://www.motorcraftservice.com/vdi...ageid=&gutsid=
click on "Owner Guides" left hand column, then select year and model number. You can download PDF file of your trucks manual.
Hope this helps
Old 03-28-2007, 05:38 PM
Beerstalker
I'm not sure exaclty what you're trying to figure out here?
Old 03-28-2007, 05:39 PM
blackhat620
DNJSDAD,
Any circuit that has a short to ground will drain the battery when the vehicle is parked. The insulation on a wire could have worn throuh at some location and now the wire is grounding to the frame or body of the truck. You need to get a test light and check for a short, this can be a tedious process.
A quick test to see if you have a short to ground, with the vehicle off and all lights and accessory switched off, is to disconnect the negative battery terminal and connect a non-powered test light between the negative battery terminal and the negative battery cable. If the test light glows, you have a short to ground somewhere.
Old 03-28-2007, 05:43 PM
Beerstalker
The thing is if it's shorting out after the fuse it should be blowing the fuse not draining the battery.
Old 03-28-2007, 05:46 PM
blackhat620
Not necessarily, if the power drain is lower than the fuse rating it does not always blow the fuse. But without him giving us a little more information i don't really know what he is trying to do. I thought i wanted to know what circuit those particular fuses controlled. Know he comes back and says his batteries are draining down. So without more information it is hard for us to help him further.
jason2022
01-22-2015 09:26 PM
jason8374
12-12-2014 11:41 PM
RCrawler
1947 and Older Ford Trucks
03-24-2014 03:03 PM
78ford351m
13
09-15-2011 05:12 PM
Jason1971
Oil & Lubrication
11-30-2002 02:36 PM
Quick Reply: What do these fuse do? 1999 F350 7.3
