Link to pics on my 63 F100
I figured out how to get the link to photobucket for all my construction pictures.
http://i170.photobucket.com/albums/u...forepaint2.jpg
Link to all pics
http://s170.photobucket.com/albums/u254/stonezones63/63%20F100%20Pics/
All are in reverse order
kstones63
___________
63 F100 project
29 Ford Sedan Delivery
Link to all pics
kstones63
___________
63 F100 project
The power window motors came out of a 02-04 Saturn 4 door(front doors). These come with the motor and regulator as a unit. You can get them cheap if you can find them with the regulator damaged(maybe free) as they are no good for replacement in a car. The gears mesh up perfect with the Ford regulator.
I took the window crank out and bolted the motors in place. The pilot on the motors works in the bushing that is under the crank. You need to weld a tab on the top of your mounts to put the top bolt in. You also need to notch out the front part of the stock mount to allow the motor to slide in. The motor needs to be tilted forward to clear the window tracks.
When you get yours out it and look at it, it should all make sense. If you need more pics let me know and I will take more and send them to you.
Kevin
kstones63
Kevin
kstones63
kstones63
24
03-27-2014 10:42 PM
kstones63
28
10-03-2012 09:51 AM
kstones63
06-30-2010 11:36 PM
