Sponsored by: Real Truck
High Idle Upfitter Question
Old Mar 26, 2007 | 10:31 AM
mr. grieves's Avatar
mr. grieves
Does hooking up the High Idle upfitter switch affect the warranty in any way? just want to confirm before I hook it up.
Old Mar 26, 2007 | 10:36 AM
johnnysF350's Avatar
johnnysF350
Nope. This feature is designed into the trucks PCM by Ford.
Old Mar 26, 2007 | 10:48 AM
nubeee1's Avatar
nubeee1
Second that motion!! easiest and cheapest mod I have. It works great!
Old Mar 26, 2007 | 11:08 PM
Super08's Avatar
Super08
Some of the dealers here in Alberta hook them up before selling them if the truck has the outfitter switches. Gives them another sales pitch when selling them here for the cold climate I guess...
Old Mar 27, 2007 | 04:04 AM
LionFan's Avatar
LionFan
Look's like I got a project for this weekend.
Old Mar 27, 2007 | 09:05 AM
msgtg's Avatar
msgtg
LionFan
Consider taking pics and posting the 'how to do it'. Somebody out there will appreciate your work.
Old Mar 27, 2007 | 09:40 AM
Super08's Avatar
Super08
Originally Posted by msgtg
LionFan
There is one here for the 03-04's
http://dan.prxy.org/Truck/Other/High..._idle_mod.html
and here for the 05-07's
%2705-%2706%20High%20Idle
Old Mar 28, 2007 | 07:25 PM
prrcatenary's Avatar
prrcatenary
Can this mod be done on the 5.4 trucks, and if so is there any point, or is this mostly a diesel thing?
Old Mar 29, 2007 | 04:33 AM
glsurratt's Avatar
glsurratt
The above link also mentions "customer access wires for CTO and VSO . . ."
Anybody know what those functions are?
Old Mar 29, 2007 | 02:01 PM
blackhat620's Avatar
blackhat620
VSO: Vehicle Speed Output (8000 pulses per mile signal)
CTO: Clean Tach Out
Hope this helps
Old Mar 29, 2007 | 02:04 PM
blackhat620
Its a diesel thing, to help prevent wet stacking during long duration idleing. Diesel engines (unlike gas engines) run cooler when idleing for long periods causing imcomplete combustion which leads to deposits on the valve stems which can lead to stuck valves. Anytime you idle a diesel for 10-minutes or more you should run with elevated idle.
High idle is also used if you run PTO driven equipemnt.
Hope this helps.
Old Mar 29, 2007 | 02:19 PM
NorCalBusa's Avatar
NorCalBusa
Is that different than the VSS (Vehicle Speed Sensor)?
Old Mar 29, 2007 | 03:31 PM
blackhat620
Yes it is. The VSS is a sensor used by the PCM to monitor vehicle speed and use the data along with other engine and vehicle sensors to adjust the engine parameters.
The VSO wire is a blunt cut customer access wire underneath the dash used to hook up accessories that need to know vehicle speed to work properly (ie GPS mapping systems that locate your car on the screen and give you current speed on there unit and time and distance to next turn).
Hope this helps
Old Mar 29, 2007 | 03:53 PM
NorCalBusa's Avatar
NorCalBusa
It does- thanks! VSS is also pulses per mile, I wonder what different characteristics VSO has? Voltage, amplitude? Etc.
Old Mar 29, 2007 | 09:58 PM
Beerstalker's Avatar
Beerstalker
Actually most aftermarket suff wants you to tap into the VSS wire. For all 05 and up trucks it is available right in the radio harness, get the scosche adapter and it has the correct output with it so you dont have to tap anything. (the bestkits and metra harness don't include the VSS or steering wheel control wire in them so you still have to splice into stock wiring)
