1949 F1 6 Cyl Upper Radiator Hose Search
I am looking for a correct upper hose for this truck. It now has a flex hose installed and it doesn't fit correctly or look right. I have done quite a bit of looking on line. Anyone out there have any sources you'd wish to share. I'll gladly cut down a hose for another application if it has the correct size ends and shape,
Thanks in Advance,
Tony
Thanks in Advance,
Tony
Rad Hose
try Macs Antique Auto Parts , National Parts Depot
I got mine from NPD. check out the site sponsors listed on the left
Bill
Bill
Originally Posted by antiqueynot
I am looking for a correct upper hose for this truck. It now has a flex hose installed and it doesn't fit correctly or look right. I have done quite a bit of looking on line. Anyone out there have any sources you'd wish to share. I'll gladly cut down a hose for another application if it has the correct size ends and shape,Thanks in Advance,Tony
Cut to fit from 51A-8333-A. Ford Obsolete stores carry this hose, which is a heavy multi-ply smooth flex with a cloth core sandwiched between the inner and outer layers of rubber as original.
Original 1951 Ford truck upper hose with a flathead 6: I.D. = 1 1/2" / Length: 11 7/8"
1949 Ford F1 Upper Radiator Hose Search
I got the upper hose from NPD yesterday and it is a piece of straight hose. In looking at the parts diagrams I see that there should be a metal elbow with straight hose at either end. This assembly has been replaced on this truck with a flex hose. Does anyone here know of a single curved hose from some other application that will go from the thermostat housing to the radiator? I will be going to my local parts store to look through the hose dimensional listings to see what I can find. Thanks for any help,
Tony
Tony
Tony
Tony
If someone does make a moulded hose, I'm not aware of it...but there should be a Ford Obsolete store in your area (Kanter is in NJ), and Joblot is in NY, maybe they know of something else. Also try Hemmings.
1949* F1 Upper Hose Search
I must appologize to this forum. This morning I went to a friend's shop and looked at a 1949 ford sedan with the flathead six. It appears that the radiator in the truck I am working on has had the radiator replaced with one where upper hose nipple comes out horizontally rather than the correct 45 degree angle. I have gone to the parts store and found a Dayco molded hose from which I can cut a section that will yield the hose that I need. Sorry for the trouble that I put this group to and I thank you for your kind responses. Once I have successfully replaced this hose I will post the part number in case anyone else runs into this problem. Thank you all again for your help,
Tony
Tony
Flathead 51
01-30-2010 05:09 PM
Andy63
12-06-2006 07:53 AM
