compression
Old Mar 25, 2007 | 02:39 PM
alie-r's Avatar
alie-r
compression
hello
i have a '78 460 block with dished pistons and heads with the numbers C9.VE-A.
did anyone know how much cc chamber these heads have, and how much cc the dishes in the standard pistons are?
i will calculate the compressionrate and i don't know these values.
thanks
andre lier from the netherlands
Old Mar 26, 2007 | 02:58 AM
darrin1999's Avatar
darrin1999
the heads have been swapped... the c9ve are from 1969 and are 72cc, and the stock dish piston from 1972-up are 22cc, if the block is a c8ve, c9ve, or d0ve then theyll have flat top pistons... d1ve and d9te blocks have the 22cc dish.
Old Mar 26, 2007 | 05:28 AM
alie-r's Avatar
alie-r
thanks for the reply
the block ia a D1VE 6015-A2b. the 22cc dish i think.
the stock compression of the block with the original heads is 8.0:1
with this heads i calculated 8.6:1 is that right?
chamber in cc's 72
piston dome in cc's -22
cilinder diameter in mm 110.78
stroke length mm 97.79
gasket thickness mm 1.1
cilinder below deck mm 1.7
i have a holley 750 vacuum second carburator
a crane camshaft (353941 powermax hydraulic) with the follow specs:
Part Number: 353941 Grind Number: H-272-2 (REPLACES HMV-272-2A)
Engine Identification:
Start Yr. End Yr. Make Cyl Description
1968 Up FORD-MERCURY 8 GOOD IDLE, DAILY USAGE AND OFF ROAD, TOWING, PERFORMANCE AND FUEL EFFICIENCY, 2200-2600 CRUISE RPM, 8.75 TO 10.5 COMPRESSION RATIO ADVISED.BASIC RPM 2000-5000
Engine Size Configuration
370-460 C.I. V
Valve Setting: Intake .000 Exhaust .000 HOT
Lift: Intake @Cam 3027 @Valve 518 All Lifts are based
on zero lash and theoretical rocker arm ratios.
Exhaust @ Cam 3000 @Valve 513
Rocker Arm Ratio 1.71
Cam Timing: TAPPET @.004
Lift: Opens Closes ADV Duration
Intake 25 BTDC 67 ABDC 272 °
Exhaust 75 BBDC 29 ATDC 284 °
Spring Requirements: Triple Dual Outer Inner
Part Number 96801
Loads Closed 114 LBS @ 1.800 or 1 13/16
Open 266 LBS @ 1.310
Recommended RPM range with matching components
Minimum RPM 1800
Maximum RPM 5400
Valve Float 6000
Cam Timing: TAPPET @.050
Lift: Opens Closes Max Lift Duration
Intake 1 BTDC 35 ABDC 107 216 °
Exhaust 51 BBDC (3) BTDC 117 228 °
is that a good combo?
i used the stock exhaust manifolds and a stainles steel dual system (2 1/4 inch).
i have a edelbrock performer intake manifold.
i did a little portwork on the heads and the exhaustmanifolds.
greetz andre lier
Old Mar 26, 2007 | 10:10 AM
darrin1999's Avatar
darrin1999
8.6 compression is about right... cam sounds decent too.
Old Mar 26, 2007 | 02:26 PM
alie-r's Avatar
alie-r
how many horsepower can i get with that combo?
good or bad mileage?
it is for a truck with a 3.54 rear end and '33 tires and a c6 transmission.
andre
Old Mar 27, 2007 | 03:32 AM
darrin1999's Avatar
darrin1999
with the holley 750 and 3.54 gears and an automatic in a 1978 2wd id say around 10 mpg... if you had a 600 cfm carb youd probably be able to get 12-14 and youd probably be around 320 horse with the holley 750 and that combo if everything was tuned properly
Old Mar 27, 2007 | 03:55 AM
alie-r's Avatar
alie-r
a holley 750 is a little big,but i run the engine on lpg/propane too.(impco 300a mixer)
than is a 750 better i think.(more cmf)
andre
Old Mar 27, 2007 | 04:38 AM
darrin1999's Avatar
darrin1999
a 300a on a 460? you should at least have an impco 425 if not an ohg 450. if you were willing to run propane exclusively then you could easily bump the static compression to 11-1 with a mild cam (like the one you listed)... if not the 425 or 450 id think about the technocarb carb with dual model e regulators... quite a bit more expensive but a whole lot more flow
Old Mar 27, 2007 | 04:51 AM
alie-r's Avatar
alie-r
with the 425 or the 450 you can not run on gasoline.
in the netherlands are a lot of lpg stations but in belgie and germany not.
if i go to germany i must drive on gasoline.
i think it's not possible a 425 on a holley carburator,isn't it?
Old Mar 27, 2007 | 11:29 AM
darrin1999's Avatar
darrin1999
it is possible but it takes a special adapter. if you want more info on it just go to http://fuelsforum.rasoenterprises.com/index.php and either frank or franz should be able to help you out
Old Mar 27, 2007 | 11:38 AM
alie-r's Avatar
alie-r
thanks for the link. i will try that
andre
CaptainIPSC
Mar 26, 2011 08:37 PM
EgoMan
Jul 13, 2005 07:43 AM
72squire
Dec 20, 2004 12:59 PM
debestuss
Nov 14, 2004 06:16 PM
popman
Apr 23, 2003 09:08 PM
