Wtf
Old Mar 23, 2007 | 07:03 PM
XylemXorro's Avatar
XylemXorro
Wtf
The other day my water pump went out which then threw off the serpentine belt. The belt had wrapped around a few things and started smoking. No big deal, changed out the water pump. Now my brakes are acting really strange. When I apply pressure, you can feel the pedal drop about half an inch, then they engage. The steering feels abnormal as well, both fluid levels are good. So what happened??? Could the belt have screwed up the power steering pump?
I know with diesels, the power steering and brakes work together somehow.
2000 X 7.3
Old Mar 23, 2007 | 07:10 PM
EpicCowlick's Avatar
EpicCowlick
Air in your brake lines? Do you need to bleed the brakes?
Old Mar 23, 2007 | 07:21 PM
betontheturtle's Avatar
betontheturtle
check your hydraulic lines for damage maybe a crimp in the line or a pin hole lots of things down there don't react well to being smacked like that.
Old Mar 23, 2007 | 07:37 PM
XylemXorro's Avatar
XylemXorro
Ya, I just realized that I should go look for any leaks. I did drive it w/o the belt since I was about 1/4 from home (luck!), and when I applied the brakes in the driveway-nothing happened. I really had to press hard on the pedal.
Old Mar 24, 2007 | 08:05 AM
XylemXorro's Avatar
XylemXorro
Looks like somethings leaking under the PS pump.
Old Mar 24, 2007 | 08:33 AM
1buzzbait's Avatar
1buzzbait
xx ya may have(hopefully) just pumped fluid out w/out the belt on, fill-er up and do sum sweeping figure 8's
Old Mar 24, 2007 | 08:58 AM
XylemXorro's Avatar
XylemXorro
Great, now I have a reason! My wife won't think I'm so crazy anymore!
Old Mar 24, 2007 | 06:37 PM
1's Avatar
See if whats leaking is red or clear/brown. Power steering fluid should be a redish color possibly a lil brown from age. Brake fluid will be clear or possible brown or black if old and nasty. Brake fluid will eat through paint faster then your eyes can pop out of your head though. Itll take it to bare paint in seconds on some underhood painted surfaces. Try to track down where its leaking from, and exactly what is leaking.
You probably shouldnt drive the truck till you find out whats going on unless youw anna risk the chance of loosing all braking. Doubt it would happen, buut better saef then sorry when it comes to brakes in my opinion.
Old Mar 25, 2007 | 09:07 AM
1buzzbait's Avatar
1buzzbait
dbl x---wtf???--- ----did it work?
Old Mar 25, 2007 | 11:38 AM
XylemXorro's Avatar
XylemXorro
I haven't done any figure eights, yet. The problem has seemed to have gone away, but I'm still gonna do some figure eights!
texasjack
24
Apr 10, 2021 10:10 AM
quality1construction
26
Feb 27, 2012 08:47 PM
hhcobra
Oct 2, 2011 10:22 PM
F350_Todd
Mar 25, 2011 04:16 PM
SmokeBlower
May 24, 2008 11:14 AM
