Clutch saftey switch
Old Mar 21, 2007 | 05:03 PM
fobranch's Avatar
fobranch
I have a 92 F350 with a ZF tranny and the 7.3 IDI. Is it normal to have to push the clutch into the floor to start the truck? How can I tell it it is my clutch saftey switch of if the cluthc needs adjusting? IT is my first 5-speed and diesel.
Thanks,
Fobranch
Old Mar 21, 2007 | 09:32 PM
F350_Hauler's Avatar
F350_Hauler
It is normal. If you look up under the dash at the top of the clutch pedal you may be able to make a small adjustment so that you don't have to push it so far down.
Old Mar 22, 2007 | 06:22 AM
gumboluvr's Avatar
gumboluvr
Yep, gotta push it through the floor. I still have the old Dual Mass Flywheel and boy is that thing tough to push
Old Mar 22, 2007 | 09:59 AM
Dave7.3's Avatar
Dave7.3
Same with mine, gotta put it to the floor when starting. Only have to push it 3/4 way to the floor when shifting though...
Old Mar 22, 2007 | 06:50 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
Your safety switch is about to the end and should be replaced. I've put 2 in my 93 so far. Sometime it might not work and leave you stranded someplace you don't want to spend the night.
fobranch
Feb 6, 2008 06:15 AM
fobranch
All Things Towing
Mar 23, 2007 05:26 PM
fobranch
Mar 7, 2007 03:58 PM
fobranch
All Things Towing
Sep 12, 2006 01:52 AM
fobranch
Sep 11, 2006 03:56 PM
