Problem
Old Mar 21, 2007 | 11:55 AM
xplore00's Avatar
xplore00
Post Problem
Went to a local autozone and pulled some codes, got these p1405, 0171, and 0174 someone help me so i can repair or replace
Old Mar 21, 2007 | 01:21 PM
mikeinri's Avatar
mikeinri
Without info about your truck (year, engine, tranny, etc.), we can't help you.
Old Mar 21, 2007 | 01:47 PM
xplore00's Avatar
xplore00
My fautl its 00 explorer 4.0 ohv 5sp 109k
Old Mar 21, 2007 | 09:40 PM
rds4ou's Avatar
rds4ou
I would guess it is the egr valve that is not working properly maybe plugged. I would start there and see where that gets you. This might take care of all the codes a stuck egr valve can trip the lean codes.
Old Mar 23, 2007 | 10:45 AM
xplore00's Avatar
xplore00
Ok another probelm my egr position sensor melted wat would cause that a plug egr ?
Old Mar 23, 2007 | 07:47 PM
MazdaRangerGuy's Avatar
MazdaRangerGuy
Usually this is caused by a restricted exhaust (usually the catalytic converters)... Those could have overheated due to your lean running condition caused by your vacuum leak.
You should probably take it to a professional mechanic on this one.
