Parking Brake
Old Mar 20, 2007 | 08:31 PM
DieselRunner's Avatar
DieselRunner
Parking Brake
so my parking brake has been loose since i bought the truck and id like to tighten it up.
simply, what is the best way to tighten this?
1991 f-250 ext cab 2WD
Old Mar 20, 2007 | 09:20 PM
Skandocious's Avatar
Skandocious
Be a little more specific... The pedal is loose? If thats the case, just look underneath your dash on the left side and its real obvious which bolts are holding the assembly onto the truck. If you can find them let me know and maybe I can take a picture of the rain stops.
-Chris
andym's Avatar
andym
Jack up the rear end. There is a small slot at the bottom of the backing plate that you put a screwdriver in and move the starwheel until the brakes are tight. Keep spinning the tire by hand and keep moving the starwheel. When the shoes drag lightly all the way around the drum, they're adjusted. Repeat for the other side.
If the parking break still isn't tight enough, you can tighten up the parking break cable. It's about halfway back along the frame on the driver's side. It has the single cable going to the cab on one side and two cables, one for each side going to the drums.
If it still doesn't work, then you either have some broken hardware inside the drums or your cables are all stretched out and will need to be replaced.
Old Mar 20, 2007 | 09:36 PM
DieselRunner
yeah this is what i ment, thanks Andy.
jdfromct
Mar 30, 2013 09:56 AM
lexustbs
6.7L Power Stroke Diesel
Aug 28, 2011 12:35 PM
PHS79
Sep 6, 2008 04:54 AM
BuickTurbo
17
Jan 27, 2007 06:11 PM
