How do you pull codes?
Old Mar 20, 2007 | 03:04 PM
Jon51F3's Avatar
Jon51F3
I'm sure it is in here somewhere, I just can't find it.
How do you pull codes on a 06' 6.0 F350?
My problem is, every now and then when I get about a mile from my house the wrench light will light on my dash. I stop, turn the truck off, restart and it goes out and stays out. this only happens about once every 2 weeks.
Will there be a code somewhere I can pull to see what this problem is?
Does the truck store codes or do you have to pull it when the wrench light is on?
Thanks
Jon
Old Mar 20, 2007 | 03:15 PM
npccpartsman's Avatar
npccpartsman
This was discussed not too long ago. I'm not sure if there's a reflash to turn the wrench light off (not needed on a diesel) or if they have to replace the instrument cluster. At any rate, the wrench light means nothing in terms of diagnostics on your diesel. You do however need to visit your dealer.
Old Mar 20, 2007 | 03:18 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
You need an ODBII code reader with CAN capibilities. Available on your favorite auction site.
