'97 Aero AWD Cruise Control Servo
I've got a '97 AWD w/a 4.0L engine whose cruise control has gone downhill rapidly (no pun intended) over the past week where it won't hold speed anymore and is almost impossible to even 'set'. I have two questions if anyone has dealt with these before:
1) Do the symptoms seem to indicate the amplifier or the servo or even something outside of those components?
2) Would the servo from a similar year/engine F-150 or Explorer also work (OEM is about $350 and eBay has a few "similar" servos for way less)?
Thanks!
Thanks!
what is the setting problem? have to push Engage switch several times? failing clockspring
is your speedometer display steady when rig is held to steady throttle speed? indicates a failure in rear axle speed sensor, wiring, connector or PSOM circuits
are you having horn problems or air bag warning light flashing?
indicates failing clockspring assemble
the troubleshooting section for cruise control problems is extensive and detailed...suggest getting a Ford service cd or dvd, avail online at ebay or dl and toast your own
http://www.fordcds.com/
the CC in the Aero is a vacuum servo system, other Fords are 100% electronic systems
Seitz372
03-30-2013 10:26 PM
1995sho
10-04-2007 03:45 PM
Lanny Sutton
15
01-28-2004 08:20 PM
