1977 351M Emission Hose routing (California)
Old 03-19-2007, 12:12 PM
FoMoColover
FoMoColover is offline
FoMoColover is starting off with a positive reputation.
Hello all,
Spring has arrived and I have finally started on my truck. The vacuum hoses are such a mess and I have been trying to get them all straight. Million has some wonderful diagrams on his site but non match all the equipment on my truck. I have a 1977 F150 with 351M and 4-speed. The sticker on the front of the left rocker cover is partially missing but what is left is 100% legible. I am able to make out ??81CC and there are some more numbers on there. The decal on the valve cover that has all the tune-up info says that the truck is non-catalyst but it has a catalytic converter. I found one of Millions diagrams that was a 49 state that had similar equipment but when I tried hooking it up, the engine runs bad due to timing issues and the EGR does not work. If someone has the original diagrams for a California truck or knows a better way to get the distributor vacuum and the EGR working please let me know. I prefer to remove as much piping as possible but want to keep the EGR. My EGR setup has the vacuum amplifier.
Thanks,
Aaron
Old 03-19-2007, 03:43 PM
Jermafenser
Jermafenser is offline
Jermafenser has a good reputation on FTE.Jermafenser has a good reputation on FTE.Jermafenser has a good reputation on FTE.
Let's get the one thing first: Where was your truck originally? Is it a genuine CA model? If you still have the door plate, throw up the numbers around the DSO area.
Old 03-19-2007, 03:49 PM
Mil1ion
Mil1ion is offline
Mil1ion is starting off with a positive reputation.
I have the diagrams I just don't have them all available.
For 1978 there were 23 351M different diagrams.
The Calibration code would be an asset.
EDIT:
Your application is 7-71J-R10
I can scan the actual Illustration of hoses for you if you want ?
Old 03-19-2007, 04:50 PM
FoMoColover
Dennis,
I would appreciate it if you would scan them for me and either e-mail them to me or something. I appreciate your help in this matter. I knew if anyone had one, you would. I love this truck and plan to keep it a long time and would like to get everything hooked back up the way it was originally. It is all there but has been jumbled up because of the trucks long stay in the garage and rats eating them. Have a look at the pics of the truck and see for yourself.
Any idea why the rocker cover decal says non catalyst when the truck does have a cat? It is a 100% California truck because it was built in San Jose and the rocker cover decal says "meets US EPA regulation for California heavy duty engines".
Thanks,
Aaron
Old 03-20-2007, 09:26 PM
FoMoColover
Bump! Dennis, appreciate the help when you have time!
Aaron
Old 03-21-2007, 09:40 AM
Pickupmanx2's Avatar
Pickupmanx2
Pickupmanx2 is offline
Pickupmanx2 is a splendid one to beholdPickupmanx2 is a splendid one to beholdPickupmanx2 is a splendid one to beholdPickupmanx2 is a splendid one to beholdPickupmanx2 is a splendid one to beholdPickupmanx2 is a splendid one to beholdPickupmanx2 is a splendid one to behold
My valve cover has Non-catalyst, has no cat-converter, only has EGR valve with vac. amplifier, so I would GREATLY appreciate diagrams ALSO!! Mine is also a 77 F-150 4speed, 4x4 short bed. I rebuilt the carb and have what I can only describe as a flat spot in the accelleration, sitting still fine, starts and idles good, but on take off/accel it hits a lull,,,,
Old 05-28-2017, 05:02 PM
mach3514v's Avatar
mach3514v
mach3514v is offline
mach3514v is starting off with a positive reputation.
I need these same vacuum diagrams...California 1977 f150 4x4 4speed 351m. The one in section 94.1 of the illustrated master parts catalog does not appear to be what I need as mine in non catalyst and does not have a thermactor
smog pump Dso 72.....thanks to anyone who throws me a life line.
Old 04-05-2018, 02:12 PM
351Montez's Avatar
351Montez
351Montez is offline
351Montez is starting off with a positive reputation.
Hello All Just Joined for some Help, Desperately looking for my 79 Ranchero GT 351M CA Emissions Vacuum diagrams Please! Its Auto-FMX it has No VECI or any stickers anywhere in the engine bay?
Ive been searching on and off for years have the Chiltons and Haynes some other manuals but not up to coughing up $ for Factory manuals just yet, I'm trying to get her back running(timing chain set swap next) But like FoMoColover shes always had a Mess of vacuum lines which I'm not even sure 100% in right locations? Id love to Reset it all with new, Organized hose routing
Let me know if you need VIN or DSO
brooklyn
24
11-19-2017 02:19 PM
ola1234
02-03-2017 10:36 PM
ola1234
12-03-2016 06:56 PM
J.McConnell
07-18-2014 09:54 PM
dimora
06-22-2004 04:57 PM
Quick Reply: 1977 351M Emission Hose routing (California)
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
