79 351M into a 91 Bronco
A question for the conversion guys out there. I have a 1979 351M and would like to install it into a 1991 Bronco. Does anyone know if the engine mounts will match and will the transmission in the 91 bolt up to the 351M without a different bellhousing? Will the A/C and P/S bolt pattern(s) match up? Basically, who knows what type of modification needs to be done....
It will NOT bolt up. The 351M uses a big block tranny pattern (same as a 460). I would not even consider the swap. The engine mounts are "who knows" what will fit. Just not a good idea. Look around and swap your 351M to csomeone who has a 351W to trade then you will be in the right ballpark.
Bob
Bob
djmac
07-29-2012 09:36 AM
Cods81bronco
06-01-2012 12:15 PM
FossenRacing
02-05-2010 09:01 PM
