1980 F100
One point of advice -
Stay THE HELL AWAY from C6 trannies, no matter how tempted you may be.
Them suckers thow away forty HP just to turn them.
And they are NOT bullet proof. I spun a gear in one going over the Cally foothills... They ain't nuthin' but a dang three speed
In that year group you'd have a freeway gear disadvantage because they were built for the double-nickle. Look up the best gearing for mileage. That will be a rear-end job.
Kit her over to manual if you can.
~Woof sendz
~Woof sendz
~Woof sendz
~Woof sendz
1980/83 F100's are a different breed when it comes to suspension and wheels. Ford made these models as a "light duty" truck. The bolt pattern on the wheels is 15 x 4.50 (not 5.50). This was the only F100 to use the 4.50 bolt circle.
That's five on four and a half. And some had a 3.8 V6.
And changing THOSE to a V8 calls for frame saddles.
And the max spring coil lift in the front without special frame brackets is about three inches.
And it has ball joints instead of the dreaded kingpins!
If I remember right - I went three inches in the body lift, three in the suspension, and added 33 inch swampers (stock diameter is 28 inches) for a TOTAL OF:
Eight and a half inches of lift - all simple jobs!
Err, except for the alignment...
Wayne Roberson
08-17-2014 11:26 PM
jschne52
03-03-2013 07:48 AM
jrocco
12-01-2001 09:12 PM
