explorer tranny
Old Mar 15, 2007 | 03:00 PM
jdye's Avatar
jdye
explorer tranny
i have a 94 explorer, automatic, 4x4. when driving it does not shift. rpms continue to climb. if you let off gas and then back on it shifts. also when going up gradual incline it downshifts and the rpms rise. i changed the tranny filter. i also removed the vacuum diaphragm hose and fluid ran out. if anyone has any ideas of the cause or problem i would appreciate it. thank you
Old Mar 15, 2007 | 04:19 PM
mrshorty's Avatar
mrshorty
If there's ATF in the vacuum line to the vacuum modulator, then the modulator is bad and needs to be replaced.
Old Mar 15, 2007 | 06:59 PM
jdye's Avatar
jdye
thanks alot. i picked one up today but i cant get to the old one. im gonna try removing the catalytic converter to access it tomorrow.
Old Mar 15, 2007 | 09:56 PM
mikeinri's Avatar
mikeinri
You COULD do it that way...
But, it's far easier (and less likely to result in peripheral damage) to remove the passenger seat and center console, peel the carpet back, and go in through the access plate (where a manual stick would go).
Mike
Old Mar 16, 2007 | 01:08 AM
jdye's Avatar
jdye
thanks for the reply
Old Mar 16, 2007 | 01:58 PM
jdye's Avatar
jdye
well i changed the modulator with no help. one thing i noticed when i took it for a test drive. the first time it needed to shift i had to let off the gas to get it to shift but then next time it needed to shift as the speed increased it did so smoothly. if that means anything to anybody. once again thanks for the help
Old Mar 19, 2007 | 11:27 PM
jdye's Avatar
jdye
i just tried adjusting the shifter cable with no help. any more ideas?
thank you
Old Mar 20, 2007 | 11:24 AM
mrshorty's Avatar
mrshorty
It seems the the governer on the A4LD is known to "stick" causing delayed shifting like you're experiencing. I don't know the specifics, but I'm sure there is information out there about removing and cleaning the governer.
Old Mar 20, 2007 | 11:25 AM
jdye's Avatar
jdye
thank you i will look into that
