Researching 302 stuff
Mar 15, 2007 | 09:07 PM
Quote:
Originally Posted by preppypyro
Looks like I wont be getting quite the HP I wanted to see out of my efi'd 302, but it will be alot better then it is now.
How much power will you be making and what were you expecting to make? Whats the engine going to be in?
Mar 15, 2007 | 09:16 PM
I figure I might get 250 horsepower if Im lucky. I was hoping for around 285 or so. The engine is going to go in my 89, im keeping it fuel injected, and turning it into a shortbox.
Mar 15, 2007 | 09:20 PM
Preppy, your max HP will depend of which size injectors you have.
16lb injectors will do 230 hp and 19lb injectors will do 275 hp.
Mar 15, 2007 | 09:29 PM
Yeah Im gonna get better injectors. I havent looked into the price of them though, I bet they arent cheap!
Mar 15, 2007 | 09:31 PM
You will have to get a chip for your computer for the larger injectors to work otherwise your engine will run very rich.
Mar 15, 2007 | 09:37 PM
Yeah a chip is no problem. They run a few hundred bucks.
Mar 15, 2007 | 09:46 PM
The best way would be to take your truck to a dyno place where they can run the engine and calibrate the chip to your engine's specifications.
Mar 15, 2007 | 09:53 PM
Thats a cool idea. Is there any places like that around stoon?
Mar 15, 2007 | 09:56 PM
Dueller that's not a pic of a Holley on the bottom it says Ford on the side of it.
Performance Plus on 22nd
www.performanceplus.com
I've never been there but they have lots of Ford goodies!
Snowking, the carbs that say Ford are a Holley 94. The off the self replacements were the only ones to have 94 stamped on them. The strongbergs always have the big linkage to the accelerator pump.
Mar 15, 2007 | 10:13 PM
So the Holley 94 is under the Ford name and the Holley 2100 where under the Holley name yet the same design of the 94 carberator?
Mar 15, 2007 | 10:17 PM
Yep the Holley 2100 is pretty much the same as the 94 but the 2100 has a spark resister thingy. Then there is the Autolite 2100 and Motorcraft 2105. Confusing huh?
Mar 15, 2007 | 10:20 PM
Why can't they just be all fuel injected, urgh, lol.
Mar 15, 2007 | 10:29 PM
Yay for fuel injection!
Mar 15, 2007 | 10:31 PM
For fuel injection there is CFI, TBI, TPI, MPI, and the various versions of each.
