Column Shift to Floor Shift
Old Mar 14, 2007 | 01:22 PM
MConstable's Avatar
MConstable
Hey guys...sorry if this has been covered, but how difficult/what's involved in converting a 3-spd column shift to a floor shift?
Thanks!
Old Mar 14, 2007 | 04:04 PM
AXracer's Avatar
AXracer
That's an easy one! Knock out the pivot pin to remove the column shift arm, disconnect the linkage at the bottom of the column to the tranny. Follow the directions for mounting whatever shifter kit you decide to use (I think only Hurst still makes a 3 speed shifter) cut a hole in the floor in the proper place for the shifter, Drop the boot over the handle and screw to the floor, screw on the **** and go drive.
