Weird Stuff Going On
Old Mar 14, 2007 | 10:27 AM
ladderdawg's Avatar
ladderdawg
1) My anti-lock brake light now stays on.
2) The overdrive light on the shifter flashes.
3) The speedometer dosen't move until I get to about 25 m.p.h.
This just started happening. Any ideas on what might be the cause.
I own a 1999 F250 7.3 Powerstroke with 86,000 miles.
Upgrades: Banks Six Gun, 4" exhaust, Evolution tuner, Air-raid intake.
Thanks in advance for any advice given
ladderdawg
Old Mar 14, 2007 | 11:05 AM
Ponyboychris's Avatar
Ponyboychris
Your VSS (Vehicle Speed Sensor) on the rear diff is out. If you look on the top of the rear diff, there is a sensor with a electrical connection to it. Get a new one from Ford - about $25.00. It takes a 10mm, I think, socket and a screwdriver to pry it out. 10 minute fix.
Old Mar 14, 2007 | 11:39 AM
ladderdawg's Avatar
ladderdawg
Will this take care of the anti-lock brake light as well?
Old Mar 14, 2007 | 12:14 PM
clintbonnie's Avatar
clintbonnie
Welcome to the Forum...You might try Napa. They are cheaper. P/N 530780 for $10.49. Fixed my problems with the flashing OD light and Speedo..(they called it a ABS Sensor). Top of rear-in and easy to replace.
Old Mar 14, 2007 | 12:29 PM
ernesteugene's Avatar
ernesteugene
If your VSS is in the Diff (like mine), and not part of the ABS, then you might have carrier bearings going bad, and metal fuzz is being attracted to the magnetic VSS and screwing up the signal. This is what happened to me, and I had similar symptoms.
Old Mar 14, 2007 | 08:24 PM
totin_tools's Avatar
totin_tools
The ABS light came on in my truck it turned out to be the front hub, both times. You might want to check them and make sure they are not going out. The second time the wheel hub went out on the highway. So now the good side is both of them are new. Some have said the flashing OD light is something going out in the trans, but when my trans went south there was no flashing light I saw. Might want to check the comuter for some codes from the trans.
Old Mar 14, 2007 | 08:49 PM
bdrummonds's Avatar
bdrummonds
I didn't think 99's could be had with ABS in the front. Mine is only rear ABS
Old Mar 14, 2007 | 09:09 PM
mcjones44us's Avatar
mcjones44us
also check your ground wire on the ABS unit. More than one of us had a ground wire that worked loose and have the exact same symptoms you've got.
The ground wire screws into the body directly in front of the driver's side battery.
Old Mar 14, 2007 | 09:27 PM
Kwikkordead's Avatar
Kwikkordead
My '99.5 has ABS in the front.
Old Mar 14, 2007 | 09:28 PM
Powerstrokedlariat's Avatar
Powerstrokedlariat
It's the VSS on the rear diff, bet money on it.
Old Mar 14, 2007 | 09:32 PM
bdrummonds's Avatar
bdrummonds
O.K. then , Sorry, I thought it started in '00.
Old Mar 14, 2007 | 09:45 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Might as well change out the rear diff fluid while you're at the VSS replacement.
Old Mar 14, 2007 | 09:54 PM
clintbonnie
My early 99 has 4 wheel ABS.
Old Mar 14, 2007 | 10:04 PM
totin_tools
I guess I should have said mine is a 2000.
