MAF Tamper???
MAF Tamper???
Was going to purchase a set of "tamper" 6 sided star bits (TORX), but was not certain if this is what is needed to remove the MAF sensor on our V10???
I would hate to purchase this set...and then come to find out that it does not work. I know I could return, but who needs the aggravation?
You knowledge is GREATLY appreciated!
Thanks,
biz
Thanks,
biz
Well the set I was looking at is only a 7 piece. But apparently there are other types of "tamper" bits available.
Again...that is just an example.
biz
Originally Posted by Example
Product Description:
Security Bits Set contains many of the most common tamper proof type security bit sizes, including:
tri-wing bits,
torx bits,
spanner bits,
and hex bits.
tri-wing bits,
torx bits,
spanner bits,
and hex bits.
biz
My MAF uses the normal TORX and IIRC the basic set I had included the correct small size
FWIW... I always by Torx sets with the hole in the center for the tamper proof pin
That said... I still have sets with no hole and most of the time if I run across a torx bolt with the pin and my bit is "normal" no hole I just break off the pin by wiggling back and forth with a jewelers screwdriver or other small implement
biz4two
11-25-2006 11:37 PM
