Super Cab Camper Special vs Super Camper Special
#46
To me,
Unless it says in the badging "Super Camper Special" it is something else...unless it can be proven on the build sheet. If Ford dropped the "Super" wording in a certain year then that would be the final year of the Super Camper Special. Of course there are exceptions such as if its a victim of a bad resto in which it lost its markings...but...unless it is designated as a Super Camper its one of the following:
1) A Camper Special-Similar to Super Camper Special but still NOT a Super Camper Special
2)A Trailer Special
3) A Regular F-350 with the bed ordered as an option from Ford by the original purchaser.
You can't make a truck into something it isnt..... just because it is similar....it still doesnt change the fact that in actuallity it is not what you are trying to make it. If they dropped the "Super" designation after 76 then that was the end of them and anything else afterward is simply not a true SCS.
Let me point out I'm not attacking anyone when Im saying this I'm jsut trying to help clarify things a bit seeing as Ford had so many trim levels, options and option packages that could even be altered for an original purchaser.
-Chris
2)A Trailer Special
-Chris
#47
[QUOTE=Mil1ion]http://www.tocmp.com/brochures/Ford-Truck/1979/1979FordTruckBrochure/FP79-14.html
http://www.tocmp.com/brochures/Ford-Truck/1979/1979FordTruckBrochure/FP79-17.html[/QUOTE]
Dennis or anybody... Do you Know what that red emblem says on the
front fender of page 13 of the links? I cant see it clear
enough to read it.
Thanks, Dan
enough to read it.
Thanks, Dan
#48
[QUOTE=Dsep]
That would be the "CAMPER SPECIAL" fender badges when ordered with the CS package.
enough to read it.
Thanks, Dan
enough to read it.
Thanks, Dan
#50
Originally Posted by 73f350sc
Should say "Trailer Special" if you look on pg. 16 you'll see the "Camper Special" emblem.
-Chris
-Chris
#52
Originally Posted by Jermafenser
The Trailer Special badge is put on the bottom center of the tailgate. Only one Trailer Special badge. Camper Special badges went on both fenders in the same place as the Crew Cab badges do.
-Chris
#53
-Chris
-Chris
different for certian years?
Both seem to look different than the ones on my truck...Hope some can post a pic of them up close. With my monitor I cant tell at all really what they look like.
#54
#55
CAMPER
SPECIAL
Only one Camper Special nameplate is listed in the exterior trim section. It appears to be a dark lettering on a light background. The emblem is rectangular. See sample.
D7TZ-16720-AD .. Emblem, Camper Special (this is an updated Ford part number and you know what that means...it replaced any and all previous nameplates),
There are three Trailer Special nameplates listed. One for the tailgate and one each for the right/left 'cab.'
1973 = D3TZ-16720-Y .. Nameplate, R/L Trailer Special-Cab
1974/76 = D4TZ-16720-F .. Nameplate, R/L Trailer Special-Cab
D6UZ-1142528-A, Nameplate, Trailer Special-Tailgate
Note that the tailgate nameplate is an Econoline (U) part number.
Yes, Econolines not only had Trailer Specials, but Camper Specials as well.
SPECIAL
#56
If you look on pg.12 youll see that truck has a tool box and not the Camper Wheel well. Hence that truck cant be a Camper Special and wouldnt have the badges for it.
-Chris
-Chris
And I should note, the trailer special emblem was placed on the tailgate on later years. Perhaps 1977.5-1979. I don't know where they were stuck on earlier years.
#57
https://www.ford-trucks.com/user_gal...=71092&width=0
Build sheet for a 79 F-350 4x4 Super Cab that that has Camper Special badges on both front fenders. They are unrestored red background with chrome lettering. Don't think there's any close up pics of them in my gallery.
#58
See though,
The whole thing thats supposedly the defining characteristic of a "Camper Special" or SCS is the big ole wheel well...correct? (At least according to the brochure)
And neither the truck in the brochure or yours has it....so that must mean that in 76-79 the Camper Specials must have been designated by some other aspect...so....
Maybe its the presence of the plug for the slide in and beefier suspension for the 76-79's that denotes a "Camper Special"
And a side mounted spare for 73-75-ish along with the other options that denotes a "Camper Special" or even SCS. If thats the case then the one in the brochure on pgs. 12 &13 could be a "Camper Special" ....but its still a mystery as to why the badge would look like its red w/ red
-Chris
Edit:
My only other thought on how to explain so much variation in the definitions of whats what is that Ford just slapped together what they thought would look good and stuck a fancy "package" name on it to lure in buyers lol
-Chris
Edit:
#60
See though,
-Chris
Edit:
-Chris
Edit:
77-79 Camper Specials?
I am in and out of the house so I may/will post when I get back in...
Dan
