79 front diff ?
Old Mar 9, 2007 | 08:25 PM
fordfaninIL.'s Avatar
fordfaninIL.
79 front diff ?
Today at work we had a 79 f-250 4x4 came in with the front diff crapped out. The customer uses this truck to plow snow. I have a friend that has a possible donor front end. The front end on the plow truck has the open outer knuckles and the donor front has the enclosed knuckles. My boss says that the donor front is not a 79, but I know for a fact that the donor truck is a 79. Will these interchange and what years use the open front vs. the closed. The best solution to the situation would be to swap the whole front assembly. I did a search but could not find the info I need. Any help would be greatly appreciated.
Old Mar 9, 2007 | 08:32 PM
Mil1ion's Avatar
Mil1ion
I assume you didn't get the codes from the door or axle housings themselves?
what ratio ?
3.54's ?
http://77cj.littlekeylime.com/Dana60.htm
Old Mar 9, 2007 | 08:33 PM
fordfaninIL.
I do not have the code off of the truck at work, but I know that the donor has 4.10's.
Old Mar 9, 2007 | 10:16 PM
plowpusher's Avatar
plowpusher
Look at where the pinion comes in closed knuckle diffs for f250's were low pinion, a 79 has a high pinion. Closed knuckle will have drum brakes the last year f250's had a low pinion closed knuckle front axle was 1975
Old Mar 9, 2007 | 11:19 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
You will need to get either the tag from the front axle and/or the axle code off the VIN plate to be sure.
Both Dana 44's and Dana 60's were offered for 1979 F250 4X4's. Both were offered with either 3.54-1 or 4.10-1 ratios.
Dana 44: Section 30.5 / Parts List # 30.5P or 30.5Q or 30.5T
Dana 60: Section 30.5 / Parts List # 30.5AA or 30.5R or 30.5Z
Old Mar 10, 2007 | 07:18 AM
fordfaninIL.
Thanks for the help guys, I appreciate it and will let you know how it turns out.
Old Mar 10, 2007 | 02:49 PM
fordfaninIL.
Turns out I was wrong, the front diff. in the donor is open knuckle. The casting numbers on the diff. are 44-96(not sure about the 6, it may be an 8) and 0385. I can't remember where I saw it, but someone had posted these #'s and now I can't find them back. I'm assuming this is the dana 44. The ring gear has a 45-11 stamped on it, which comes out to 4.09.
Old Mar 10, 2007 | 02:56 PM
NumberDummy
Have the donor vehicle nearby? Post the axle code off the VIN plate/sticker.
Stamping on diff: 44.9F?
Old Mar 10, 2007 | 03:02 PM
fordfaninIL.
Unfortunately I don't have the donor vehicle close, and like an idiot I did not write the info down.
Old Mar 10, 2007 | 03:08 PM
NumberDummy
What is needed parts wise to install the front end? What is in the current vehicles front diffy, a Dana 44? Have it there? Post the axle code from it...
Old Mar 10, 2007 | 03:14 PM
fordfaninIL.
Both diffs look identical. The 44.9f might be correct as I could not make out the last digit on the housing very well.
Old Mar 15, 2007 | 06:06 PM
fordfaninIL.
Just to update, the diffs are both the same. Got them switched out late today, but now I have a brake question. Will a single piston caliper work in place of the dual piston? There is $25 difference in the price for the caliper and pads for the single are $10. The customer only uses the truck for plowing snow and around his farm for odd jobs, so I would think that the single would be suitable.
Old Mar 15, 2007 | 08:57 PM
unrulee's Avatar
unrulee
25$....$10.....go with what's supposed to be there, the dual piston stuff. You'd spend more trying to get single piston stuff under there anyway.
Old Mar 15, 2007 | 10:27 PM
Jermafenser's Avatar
Jermafenser
What unrulee said...dual pistons are better as well.
Old Mar 16, 2007 | 01:04 AM
FordTrucksKickGM's Avatar
FordTrucksKickGM
For 15 bucks might as well get the right one.
