towing a 5th wheel with a Excursion
Wow, came across this gizmo and sure enough, you can pull a 5th wheel with an Excursion or Van.
Its kind of pricey at 5k, but opens up some interesting possibilites.
If I ever come across a used one for sale I'll be all over it.
Another application would be to use this with a pickup, since all the pin weight is on the tow buddy -not on the truck- you can still load up the bed of your truck with heavy payload.
http://www.hitch-buddy.com/5th_wheel_app.aspx
Texan, that thing looks spooky to me. I think I'll stick with the normal 5ver. Has anyone else used the B&W hitch with the Companion to match? I just got finished assembling the Buddy hitch and it won't wrap around the king pin. I'm going to try and do some adjusting tomorrow with a torque wrench and then try again. Just wondering if I done messed something up.
It looks like kind of an interesting device, but.... Why would anyone want one. If you looking for a truck and trailer combo, then you would buy something that matches. ie fifth wheel hitch = pickup & Excursion = conventional. If you already own a fifth wheel and needed a truck, then you wouldn't consider an Excursion. If you already own an Excursion, then you wouldnt shop for a fifth wheel. I think I'd put the five grand to a better use.
