Best way to temporarily disable the truck?
you can also remove the start relay in the fuse panel and put it in a safe place then just plug it back in when you want to restart it. it located in the fuse panel and is one of those big black square looking things. The manual tells you which one does what and so on. I had a problem with this and found out it was the relay that was bad. its a quick and fast one too.. jeff
on
Originally Posted by cgl
I pull the Injector Driver relay out. It's a relay in the cab, granted this is on an 02. I typically do it at airports. I forgot I pulled it out once and was almost pissed when she wouldn't start.. then I remembered.
Haha!
Put your girlfriend in it and tell her "I'll be right back" - no one in their right mind will go anywhere near your truck then!!
OR
Put a big note on the steering wheel saying "I paid the kid across the street $10 to call the police and report this truck as stolen if it moves. He's got 2 broken legs and ain't going anywhere, and my truck better not either. But there's soap-on-a-rope in back in case you can't resist"
The PCM fuse is probably your best/easiest option, short of getting a DP Tuner.
OR
Originally Posted by rad1026
OK, all these suggestion of taking the #9 PCM fuse out, or removing relays, etc. Is this safe to do with the batteries connected? Especially anything to do with the PCM?
I can't believe how many helpful? tips that have been given here for someone with a legitimate question.
#29
Ok, thanks all so far for the "variety" of responses ranging from the reasonable to ridiculous; however, I still don't think I have a solution which accomplishes my goal. The disabling technique needs to be:
- Quick (a minute or to tops)
- Temporary (completey reversible with no issues)
- Hidden (average person (i.e. non-FTE enthusiast) can't easily figure it out)
- Safe (No damage to the truck)
Note: There are multiple sets of keys to the truck so some one may indeed attempt to start it.
Note2: I do not have a chip. Well not yet anyway, I'm waiting for Jody to create pod mount first. Change my 3 pod to a 4 pod . . . blah, blah blah . . . anyways back to the point.
Best Technique Submitted so far:
The best techniques submitted so far is to pull a relay and/or fuse to disable the starting. However, if someone has a set of keys I don't want them ruining the starter or draining the batteries by continuing to crank on it. So the objective of safe hasn't been met.
Other techniques typically weren't quick (remove tires, steering wheel, etc.) or practical (having someone watch it) so won't be considered for my purposes.
Ideally, the outcome of the technique would simply disable the starting such that if someone did have a valid set of keys and tried to start it absolutely nothing happens as if it didn't have batteries attached. However, I don't want this method as even an average person could pop the hood and immediately see the batteries disconnected.
I really am looking for a solid solution and believe it a technique meets the objectives there would be numerous FTE's that would use it.
Keep the ideas coming.
#30
To add another suggestion go out and buy a "Club" then they cant move the steering wheel.
But seriously why cant you just get all the keys and hide them....thats the simplest one of them all I would think as long as you dont forget where you put them.
We all kinda need the whole story, are you afraid of someone you dont know stealing it? Some one that has access to your keys takeing it for a spin? Are you storing it somewhere and dont want it moved? whats the deal.....I think just pulling a relay would be the easyest, or the batteries. If someone pops the hood and see's the batteries gone do you think they will go out and buy two $50 too $70 batteries just to start it up and drive off somewhere. Well I hope all possible solutions havnt been exhausted. Good luck!
