CCV mod
Old Mar 8, 2007 | 01:42 AM
redneckboy's Avatar
redneckboy
CCV mod
From what i have read you want to get the least amount of restriciton at the end of the hose is this correct? the whole vaccum stuff has got me confused and the reason i ask is cause i havent got around to building guzzles trap and want to make sure i wont screw nothing up by driving around with the hose wide open till i can.
Old Mar 8, 2007 | 02:54 AM
ron's power stroke's Avatar
ron's power stroke
correct...most guy's run the hose to the back and put nothing on it..
Old Mar 8, 2007 | 06:34 AM
Izzy351's Avatar
Izzy351
That's what I did. I replaced the CCV coupler in the hose with a piece of thin 4" PVC. It was a little tight, but it fits. The hose is run over the master cylinder then along the frame. I crossed mine over the axle to the other side so it vents near the exhaust. No oil drips that I have seen.
Joe
2002 7.3L F250 XLT CrewCab ShortBed 2WD
Old Mar 8, 2007 | 07:46 AM
aklim's Avatar
aklim
If you don't mine it fuming leave it as it is. If you do and/or want the crankcase to be under vacuum then run it into the exhaust. Exhaust will pull the gases out for you if you set it up right. Pay attention to post #22 on the thread below.
https://www.ford-trucks.com/forums/4...questions.html
Old Mar 8, 2007 | 07:47 AM
Kwikkordead's Avatar
Kwikkordead
Mine comes down to right below the driver's seat and smokes.
Old Mar 8, 2007 | 04:05 PM
redneckboy's Avatar
redneckboy
all right thank you guys. I dont mind the oil leak cant stand the white smoke though if it was black i would be good with it.
