57-60 P/U Air Vent & Choke Knobs
Old Mar 7, 2007 | 10:29 PM
Monte Doenz's Avatar
Monte Doenz
57-60 P/U Air Vent & Choke *****
I purchased new air/vent ***** from Dennis Carpenter and notice they have a brass threaded center whereas the original ***** on my 59 p/u are not. The original look like they were pressed onto what looks like barbs on the cable side. To install new ***** does one run a die over the cable shaft that matches the same thread as the new **** or are there correct ***** to purchase like the original style??
Thanks for your help!
Monte
Old Mar 7, 2007 | 10:53 PM
airharley's Avatar
airharley
It sounds like you were sent the wrong *****. ***** into the mid 60's were pressed onto a barbed clip that slide over the shaft and locked on. Try calling them to see what they say before you thread your cable shafts.
Old Mar 8, 2007 | 12:07 AM
Col Flashman's Avatar
Col Flashman
Press-on for the Most part, though I've ran across a tick or 2 that were secured by a tension screw.
Old Mar 8, 2007 | 07:39 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Monte Doenz
I purchased new air/vent ***** from Dennis Carpenter and notice they have a brass threaded center whereas the original ***** on my 59 p/u are not. The original look like they were pressed onto what looks like barbs on the cable side. To install new ***** does one run a die over the cable shaft that matches the same thread as the new **** or are there correct ***** to purchase like the original style??Thanks for your help!Monte
The ***** were originally white with white centers. Pictures in the parts book show ***** coming with air vent cables as an assembly (B9C-8101890-A) only. These ***** were only sold with the cables back then. You might give 'ol Dennis a call, to find out if A: They sold you the correct parts, and B: What's the trick to installing them.
Old Mar 8, 2007 | 06:41 PM
Monte Doenz
I talked to Dennis Carpenter and just like I thought, use a 10-32 die run it over the cable shaft where **** goes and cut new threads.
Monte
Old Mar 8, 2007 | 09:21 PM
Col Flashman
It'd be far easier to just get a complete Used or N.O.S. cable w/ a good ****.
Old Mar 8, 2007 | 11:01 PM
Monte Doenz
Finished both L/R vents and choke cables tonight with no problems. Most original ***** on the dash I have seen are oxidized and deteriorated to point they crumble in your hands. What worked real slick to remove old ***** is put them up against a wire wheel on your grinder and the old material comes off like chalk.
Monte
Old Mar 8, 2007 | 11:37 PM
Col Flashman
Not been my experience one wit, but that could be a Regional thing as well.
