suspension sucks!!
suspension sucks!!
My 97 Power Strokes suspension has got to be the WORST riding truck I have ever owned or drove!!!.. Does anyone Know of a fix other than completely removing all of it? And if I remove it what should I replace it with? I thought about air bags but, lots of money but I would do that if I could find a less expensive way. I know its a truck not a caddy but this just SUCKS!!!
Every one has been so helpful in the past so I want to say thanks again!!!
on
you can do a shackle reverse and super duty springs up front if you are good at fab work or have a fat wallet to pay somebody else to do it. or you can just use sky manufacturing RSK (reverse shackle kit) and reuse your original springs. The RSK with stock springs will be much better than stock and the RSk with superduty spring is the best possible solution aside from air ride with 4 link.
Is it a f-250 or 350?
(click here)
You can use this kit along with a set of newer superduty leaf springs and get a much smoother ride.
(click here)
on
yep thats the kit! the superduty springs require alot more fab work cause they are about 4 or 5 inch longer on the front side. the front bracket has to be moved as far forward on the frame as it can go which then interfers with the bumper mounting. it can be done with very good results just takes lots of fab work.
I found it the 2" springs for the front.
http://www.suspensionconnection.com/...on/282803.html
Here is the old thread about the front suspension. I think it should pretty much answer all your questions. I haven't done this mod yet but its on my list.
https://www.ford-trucks.com/forums/5...nt-lift-3.html
