New Brakes are GREAT!... But Needle bearing maintenance, Help please
I was having the typical "warped brake syndrome", so I decided to go with the Cryo slotted rotors from Advanced Brake Technology. I have 62,000 miles so decided to do the needle bearing service and auto hub service while I had things apart. Everything was very straight forward, got it all back together no problem. Blead all the old brown brake fluid out and drove around and followed the procedures for "bedding" the pads. Brakes are awesome, really happy, but I have a vacuum leak in the hub and my ESOF is not engaging. I don't know what I could have done different. When you put the new "O" ring in and slide the hub back in and tighten the 4 nuts to seat the hub there is really only one way it can go in. I noticed when I disassembled the hub, there was alot of bearing grease where the hub meets the axle housing, but in following Guzzle's pics there was no mention of using bearing grease anywhere but the needle bearings. Maybe I need to take it apart again and grease it up better? I'm going to get a vacuum gauge tonight and test each side. I don't think I have any choice but to disassemble again, will I need new yellow "O" rings again? Give me some help guys, I'm taking a trip soon and need to get this to work.
I bought a vacuum guage last night and hooked it up to each hub vacuum line and pulled to 20 in-Hg as it states in the manual. Each side held the 20 in for several minutes, so I knew it wasn't the o rings leaking. I started the truck up put it in 4wd and everything works perfectly. AC vents are fine also. I think the vacuum test may not only verify the o rings seating properly, it may also engage the rubber diaphram in the auto hub in to the correct seating position. Anyway, it all seems to be working correctly now, thanks for the suggestions everyone. I'm all happy, new brakes, and needle bearings are good for another 60,000 miles. Next up, I have to track down a small oil leak.
