Crankshaft Position Sensor wiring harness??
Old 02-09-2017, 05:43 PM
twozzie's Avatar
twozzie
twozzie is offline
I am replacing my Crankcase sensor and want to change the harness too (looking to clear codes P0316/P0305). I can't find anything in any on line catalog to get a part number for this harness. Anyone know where to get one or what the part number is?
Old 02-13-2017, 09:50 AM
pawpaw's Avatar
pawpaw
pawpaw is offline
I see you don't have any replies yet, so I'll see if I can get things started. You might enter your vehicle info here & go through the drill down & see if you can find what your looking for. Official Ford Parts Site | Buy Motorcraft & OEM Ford Parts Online | FordParts.com
If your looking to buy new, a Dealer parts guy could probably look up what you want, or maybe send FTE member & former Ford parts guy Number Dummy a PM, bet he'll know where to find what you want.
Lastly if you want used, I should think any good salvage yard could come by what you want.
Some thoughts for consideration, let us know how it goes.
Old 02-13-2017, 09:59 AM
twozzie's Avatar
twozzie
twozzie is offline
Thanks pawpaw. That Ford parts link was the first I tried.
The car may need to go to the dealers as I changed plugs, leads, coil pack and will be changing the sensor but the message still appears and I don't think the car is running as it should but I have no comparison. Starts OK, ticks over OK, drives OK but feels a tad rough and gives those damn codes.
ill keep plugging away though.
Cheers
Old 02-13-2017, 10:12 AM
pawpaw's Avatar
pawpaw
pawpaw is offline
Which thread has all of the code numbers your now working?
Old 02-13-2017, 10:13 AM
twozzie's Avatar
twozzie
twozzie is offline
There is no separate thread, it's in my first post, P0305 & P0316.
cheers
Old 02-13-2017, 10:16 AM
pawpaw's Avatar
pawpaw
pawpaw is offline
Ok, well did you ever get a vacuum gauge on that puppy & have a look see for clues on the vacuum gauge tutorial link I posted?
Old 02-13-2017, 10:32 AM
twozzie's Avatar
twozzie
twozzie is offline
Not yet, trying the easy stuff first, not mechanically minded, but really appreciate the help.
Old 02-13-2017, 10:50 AM
pawpaw's Avatar
pawpaw
pawpaw is offline
Ok, well it doesn't get much easier than hooking up a vacuum gauge & let it & the link test scenarios suggest where best to look next in your trouble shoot.
Or, if you have, or can come by a scan tool that'll do a cylinder balance test, that test is easy too & can pinpoint questionable cylinders while you sit in the drivers seat.
Lastly, do you have, or can you come by the inexpensive ELM scan tool running FORScan, or the like diagnostic software on the viewing device of your choice, as discussed here https://www.ford-trucks.com/forums/1...-scantool.html & have it take an in depth look at whats going on with fuel trim, ect, as that too is easy & can be done from the drivers seat, or while driving.
More thoughts for consideration, let us know how it goes on the "Engine FUBAR" thread here https://www.ford-trucks.com/forums/1...ine-fubar.html.
Old 02-14-2017, 11:12 AM
tomw's Avatar
tomw
tomw is offline
I'd close this one off, and concentrate on the other post. The codes are the same, the problem the same, and this is a specific parts question which has been answered. Right?
tom
Old 02-14-2017, 01:12 PM
twozzie's Avatar
twozzie
twozzie is offline
no issue, cant see how to close it though, sorry
Norton72
09-14-2023 12:36 PM
ofullard
22
06-22-2017 11:16 AM
kornfanjoe
03-13-2013 06:09 PM
dpmp154
12-03-2009 09:12 PM
buffalobill
Aerostar
11-19-2003 12:47 PM
Quick Reply: Crankshaft Position Sensor wiring harness??
