Magnesol & Filters
The "no plastic parts thing" has nothing to do with the Nitrogen purge. I'm working with the local FPD and the State Fire Marshall on the new ranch plant. It will have a capacity of 100,000 gallons per year, and SAFETY was our first concern. If it melts it's not in the plant.................The Nitrogen is used as a "blanket" inside all tanks, eliminating the Oxygen for combustion, and preventing Oxidation of the Biodiesel.
Originally Posted by willbd
What is your source for N2?
Hey guys, i just have question about that Magnesol thing, i just order it, and i did my first batch, i drain of glicerol, run it through 15 micron filter,
now can i use my clear water pump to mix magnesol, or whats the best way to do it, im limited with options, i have cone bottom setteling tank,
can i use bubbles to mix it,
can you guys give me some input ? im new to this stuff,
please
thanks
Peter
please
thanks
Peter
please
thanks
Peter
please
thanks
Peter
fabman,
Found this place through a friend. http://www.floridabiodieselinc.com/biodry.html It's a little cheaper have you heard of them.
Originally Posted by Talyn
Jee, You guys had to throw another wrench in it for me. This is the first time i've read of this step.
#30
when running your magnasol, why dont you simply make a magnasol filter, and filter the diesel through there with a pump?
It will not be pumping the magnasol, so it wont break appart, and if you use a small micro filter, you will be filtering out some left over impurities in the bio.
I would think, x hours through the filtering process will have the same effect as a mix for it.
I can think of a few different ways to set up the filtering system, and in the end you dont have to strain out them magnesol, you just leave it in the filter, or filter container.
If this woudlnt' work, why?
