Where to buy wiring harnesses?
Other than the Ford dealer ($$$$$). I'm specifically looking for the harness that connects the starter, starter solenoid, and battery. I've looked just about everywhere I could find online, and no luck. I don't want to get one from a junkyard, as it'll probably have the same problems with old wiring and corrosion that my current one has.
Anyone know a good place to buy one?
I have used the junkyard alot to put my 96 bronco back together. It is a yard that only deals with late model cars and trucks. I tell you I have saved hundreds of dollars on things such as door panels to a mass flow oxygen sensor. I also bought two wiring harnesses for a fraction of what a dealer would charge. I just took my time and found ones in good shape. Alot of pickup parts work on the broncos so there was lots to choose from. Good luck.
Check out Painless wiring they make about the best after-market wiring harnesses.
http://www.painlessperformance.com/
Hope this helps and Good Luck,
Rick
86 302 EFI, bored 60 over, AOD,
Headman Headers, Flowmaster 40 series,
2 inch dual exhaust, MSD ignition
Rick
maclif
07-06-2016 01:27 PM
kaden78ford390
11-03-2015 09:23 PM
F-250 Super Duty
13
01-26-2009 05:50 PM
honeyb
01-03-2009 10:22 PM
