OH MY GAWD! I can't believe this! HELP!!!
wipe the coolant out of the cyclinders. pour some oil on a rag, ( clean oil) wipe down all the cyclinders with it.
you have already drained the contaminated oil out. Refill with fresh oil, run the engine for about 10 minutes after it has came up to temp and change oil again. refill and rerun the engine. Check the oil to see if it is milky it so, change it again and again until the oil is cleaned out.
I think you are thinking of the engine cleaner. It's basically diesel fuel (or kerosene, they are similar). You add it to you oil, run it at idle for 5-10 minutes, then change your oil.
Personally, I wouldn't do it, especially on a new motor. If all you have is radiator fluid mixed in the oil, then just refill with cheap oil, and change after 10 minutes as said before. When your oil comes out clean, put in the good stuff.
carpe_diem
13
08-11-2019 06:05 AM
96f-150
15
06-22-2012 03:21 AM
88grandmarquis
11-03-2009 07:09 PM
heybrent
1978 - 1996 Big Bronco
23
12-22-2002 05:42 PM
