3/4 ton running gear swap
I want to put the running gear from a 1984 F250 under my 1979 Bronco. Now I know I will have to use the spring buckets off my old axle. But I need to know if there is anything else I will need to do the the 3/4 ton front axle for it to work under my Bronco (steering, radius arms,etc.).
thanks for any help
1979 Bronco XLT
1968 F100 stepside 4wd
thanks for any help
1979 Bronco XLT
If I remember correclty, the front axel under the 250 would be a Twin-Traction beam Dana 44 or Dana 50. Thiss would not work under a '78 Bronco, since that year yaer they were equiped with a solid front axle. If you want to convert it to a 3/4 Ton bronco, you will need to find your 8 lug rear axle (Dana 60 or Ford 10.25) and then a solid dana 44 HD, which can be found under the frontside of mid to late seventies 4x4 pickups.
Yup, the '84 F-250 will most likely be a TTB suspension. Although is is technically possible to put that in your '79 Bronco it's a step down from the solid axle you currently have. You really need to find the front axle out of a 77-79 F-250, any older & they will have drum brakes & closed knuckles. Another issue is that I believe the front suspension will be leaf sprung on those trucks, the '76 F-250 I had was. You will have to change it over to coils & radius arms if it is.
>I thought the F150 was the only one with the ttb front end.
>But I will have to look closer at the truck.
No, F250s got leaf sprung TTB from '80-97 (yes, '97!) and even F350s got it from '80-'85ish.
Dont' waste your time. Throw a full floater in the rear and convert your current front to 8 lugs.
ford-harto3457
07-12-2009 11:22 PM
