Oil Bypass Filtration System - Which??
I will tell you this. Compare the ongoing costs to the initial cost of purchase. All the filters will do a good job, compared to nothing. The Oil Guard unit has a low filter cost vs. say the FS2500 which will cost you more per filter. I personally use the FS2500 on my engine and tranny. I am sold on its capabilities. I have used the Amsoil unit in the past. I do not like the set up. Too big and filters are exposed to being punctured if mounted underneath the frame somewhere. Even the toilet tissue units will work, but I am skeptical of the performance long term and the filter must be changed often.
Good Luck
edit: the tp unit is Motor Guard, one anyway, there are others.
Good Luck
bigpimpin
12-01-2013 02:45 AM
