33 on the stock tire carrier?
I plan to, but my local tire retailer told me that It can be done with a stud extender, or wheel adapter from your local 4x4 shop. I have not had the time to go to my local shop and find it yet. A 12.5 in. wide tire won't fit on the stock spare tire carrier as far as I know. Good luck finding the adapter.
[updated:LAST EDITED ON 03-Oct-02 AT 09:14 PM (EST)]>
>Anyone carrying a 12.50 x 33 on the stock spare tire
>carrier?
>Tom
Did it for a while on mine. I just used some 2" x .120" wall square tube for spacers between the carrier and the frame, and used longer bolts. Worked great and was cheap, too
>carrier?
>Tom
Just a thought. If the actual wheels that your larger-than-stock tires are mounted on have the same or shallower (smaller measurement) backspacing, it would seem the the larger tire would still mount to the factory spare carrier. To be absolutley certain though, you would have to take into consideration additional tire section width as well. I am about to go to 33x12.50's as well and its a very good question that I most likely wouldn't have thought of 'til I tried to stuff the larger tire onto the carrier.
