E4od
Old Feb 22, 2007 | 01:15 PM
bricklayer's Avatar
bricklayer
E4od
I have a 90 with an E4OD.Does that trans have any control on the throtle.I take off the truck runs fine,seems to shift,but then it will not realy respond to my foot on the pedal.I will pull the truck over, shut it down and restart.Once again everything repeats.The injection pump seems to work well at low and hi rpms when the truck is in park.I have a 86 with a manual since it was new but I dont know where to start with the E4OD.
Old Feb 22, 2007 | 01:40 PM
PLC7.3's Avatar
PLC7.3
Actually the trans gets it's info from the throttle..... sounds like the TPS/FIPL is not working..... Are you getting any codes set. Does your speedo and tach work flawlessly.
Unplug and reinstall the electrical connector on the FIPL, drvrs side of the IP, vertical 3 wire connector. I will PM you test/reset info...........
Old Feb 22, 2007 | 03:30 PM
bricklayer's Avatar
bricklayer
Hey- The speedo and tack are working.So I am going to guess the IP has a problem.I,ll be looking for that test/reset info. Thanks!
Old Feb 22, 2007 | 07:05 PM
Ben-jamin's Avatar
Ben-jamin
are you saying you have an acceleration problem or lack of control with upshift/downshifting
Old Feb 22, 2007 | 07:32 PM
bricklayer's Avatar
bricklayer
I have an acceleration problem-If I run the engine up to 2000rpms after about 20 seconds or so it will slowly back down to a rough idle and almost stall.This rpm change happens without the throtle moving.The truck will idle fine and responds well to throtle movement when first started but after 1/4 mile it acts as if the throtle no longer works.
Old Feb 23, 2007 | 02:26 PM
bricklayer's Avatar
bricklayer
I changed the IP and everything works again.Down the road I go!
Old Feb 23, 2007 | 05:00 PM
rockcrawlerdude's Avatar
rockcrawlerdude
hey can you PM me with the reset.. my speedo works fine but my tach works but not at low rpms( @ idle and slightly above)... thanks nathan
AF_MAC
Jul 5, 2014 06:45 PM
deere81
Nov 21, 2009 08:23 AM
captain_trucks
Oct 27, 2009 06:55 PM
fordtruckboyf150
26
Mar 19, 2007 08:14 PM
ExcellentRed
Feb 7, 2004 11:25 PM
