Performance Needs...
Old Feb 21, 2007 | 10:33 AM
Gofigurethis_01's Avatar
Gofigurethis_01
Lightbulb Performance Needs...
My first Ford Truck was a '90 F150 4x4 with the EFI 4.9 and a four
speed. High miles and fuel consumption retired the truck to the farm...
I always liked the six and now I would like to build a highly respectable
torqued-out performance version...
Where to start? I see cams everywhere, flat top pistons, headers,
intakes, chips for EFI, and the list goes on.
How many ways can this be accomplished? Has anyone built a low-
end hauler? What kinds of mods? Maximum bore sizes? Aspiration?
If only I could find a sroker crank!
Any and all input and experience would be appreciated, Thanks!
BTW, and "oh yeah, i got a turbo laying around too..."
Old Feb 21, 2007 | 03:21 PM
I6power's Avatar
I6power
Do a search and youll find all the info you want. Including any questions on the turbo.
Old Feb 21, 2007 | 04:06 PM
scottfreeman's Avatar
scottfreeman
Mine runs 300hp, 300ft-lbs naturally aspirated. great torque monster.
Old Feb 21, 2007 | 04:28 PM
Gofigurethis_01
Thumbs up
Very impressive! Thats what Im talking about!
Old Feb 21, 2007 | 09:28 PM
scottfreeman
I think there is still more to be had with more of the Green stuff. I want roller rockers and do a roller cam conversion some how. I hear Side Draft Webers make a ton of difference also.
Old Feb 22, 2007 | 12:09 AM
NavyMIDN08's Avatar
NavyMIDN08
if you're looking for a stroker crank, take a look under my past posts, or do a search for col. flashman. there was a recent string discussing the method of getting a stroker crank for the six. its called offset grinding, and its about the only way other than a custom order. make sure you get the right turbo, as the wrong one will not help, and may hurt, or destroy your engine.
Old Feb 22, 2007 | 12:11 AM
NavyMIDN08's Avatar
NavyMIDN08
okay... i found it, col. has a very nice, clean, quality build...
https://www.ford-trucks.com/forums/5...questions.html
check out his gallery and build stats
Old Feb 22, 2007 | 04:26 PM
I6power's Avatar
I6power
Is that estimation or dyno results?
Also, what have you done to your six?
Old Feb 22, 2007 | 06:18 PM
Bdox's Avatar
Bdox
I think you can spend your money more wisely than increasing stroke. The 300 is basically a stroked 240. It's greatest performance deficiency is in the the breathing department. The stock intake and exhaust manifolds are restrictive and so are the ports and valves. If you want to go all out, increasing the valve size, porting and polishing is probably your best starting point. Lots of people have gotten good performance with the stock valves, but the ultimate rpm is limited. The bottom end can take all kinds of top end mods though. An easy route to higher compression is to start with a 240 cylinder head and go to work on it to improve the breathing capacity.
Dual Webers are great, but you have to do head, cam and headers to take advantage of the additional flow that they offer.
Old Feb 23, 2007 | 10:07 PM
scottfreeman
Thumbs up My 300
Starting at the top:
Ported & Polished 240 head
Bigger Valves, 5 angle valve job
Offy DP Intake, Holley junk 390cfm
Hedman full length headers
2.5" x-pipe, dual 3" exhaust
Fischer balancer from Clifford
Bored to 309 cid
9.5:1 compression
rebalanced rotating assembly
custom ground cam
Pertronix, distributor curved for application
MSD 6A, MSD Offroad coil
Old Feb 23, 2007 | 10:31 PM
SilverFish's Avatar
SilverFish
I gots a 300 stroker wit a cliford 4bl intak holy 650 dp and header we put a sniper nos kit on dat thang and man it runs like a alley cat on fire!
Old Feb 23, 2007 | 11:19 PM
ibuzzard's Avatar
ibuzzard
See A Man About A Horse
Wasn't you da kid playin da banjo on da porch in dat Deliverance movie,Silverfish?
Old Feb 24, 2007 | 12:20 AM
SilverFish's Avatar
SilverFish
ha ha buzard boy make fun i no my spellin aint much to look at, just puttin my 2 cents in
Old Feb 24, 2007 | 05:34 PM
scottfreeman
alley cat on fire is a strong visual, must be pretty fast.
Old Feb 24, 2007 | 06:01 PM
Bdox's Avatar
Bdox
Or six of them in a line.
