89' 460 Studder problem
Old Feb 20, 2007 | 05:09 PM
Drewbear460's Avatar
Drewbear460
The truck has a pretty bad stumble/studder between say 900 and 1800rpm. it is most noticeable due to a loss of power and the shifter/4wd select lever spinning around/moving like crazy up in the cab. i cant hear the engine misfiring, all i feel is a power loss/studder and the shifters moving around.
it all started when i changed the o-rings on the #5 injector due to a leak. In the process, i managed to bend the pintle on the injector, and had to replace it with one from advance auto.
i have since switched back to a bosche blue top injector, replaced the dizzy cap and rotor, replaced the foward-most coolant temp sensor on the intake manifold, and the studder is still occurring.
I have pulled the spark plug on cylinder #5, and it looks alright (at least according to this site: http://dansmc.com/Spark_Plugs/Spark_Plugs_catalog.html). It is neither soaked with fuel and really black, nor white and corroded.
i think this weekend im going to try to swap out all of the injectors with the new ones ive bought, to see if that makes any difference.
Any ideas anybody has would be much appreciated, im at my wits end with this problem. thanks!
-Drew
Old Feb 20, 2007 | 06:42 PM
airharley's Avatar
airharley
Have you tried cleaning the throttle body and IAC valve? Sometimes they send a faulty signal to the computer if they are dirty. If the injector was faulty you would have the stumble throughout the entire rpm range. Your problem is only on the tip in of the throttle.
Old Feb 20, 2007 | 08:32 PM
Drewbear460
well, whatever it is it seems to have gone away. i just did the cap, rotor, and changed the advance auto injector out for a bosch replacement today. after doing so i went on a ~45 min drive, and about half way through the drive the studder just up and went away. go figure.
hopefully it will still be gone when i go to drive it tomorrow morning.
thanks for the reply though!
Old Feb 21, 2007 | 10:21 AM
airharley's Avatar
airharley
That does make a little sense. The computer was probably trying to reconfigure for the new injector. Glad it went away though.
id_birdhntr
Sep 24, 2012 04:03 PM
mblanken881
Jan 17, 2012 09:27 PM
76fordtruck
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Feb 8, 2006 01:04 PM
rangerchief
1983 - 2012 Ranger & B-Series
Feb 27, 2005 09:59 PM
Trav460
Feb 16, 2004 11:04 PM
