Offroad & 4x4
off road/spot lights illegal in illinois
Old 02-20-2007, 07:40 AM
bigbubba87's Avatar
bigbubba87
bigbubba87 is offline
are spotlights or off road lights illeagal in illinoils ive heard that you get a couple hundred dollar fine if a cop catches you with them on ur truck without covors is this true?
Old 02-20-2007, 09:15 AM
Thomasm67's Avatar
Thomasm67
Thomasm67 is offline
(625 ILCS 5/12‑207) (from Ch. 95 1/2, par. 12‑207)
Sec. 12‑207. Spot lamps and auxiliary driving lamps.
(a) Any motor vehicle may be equipped with not to exceed one spot lamp and every lighted spot lamp shall be so aimed and used upon approaching another vehicle that no part of the high‑intensity portion of the beam will be directed to the left of the prolongation of the extreme left side of the vehicle nor more than 100 feet ahead of the vehicle.
(b) Any motor vehicle may be equipped with not to exceed three auxiliary driving lamps mounted on the front at a height not less than 12 inches nor more than 42 inches above the level surface upon which the vehicle stands.
(c) The restrictions of subsections 12‑207 (a) and 12‑207 (b) of this Act shall not apply to authorized emergency vehicles or equipment used for snow and ice removal operations if owned or operated by or for any governmental body.
(d) The minimum and maximum height restrictions prescribed in subsection (b) of Section 12‑207 shall not apply to privately owned motor vehicles on which a snow plow is mounted, while in transit between or during snow and ice removal operations. This exemption shall apply only during the period from November 15 through April 1, and only when the snow plow blade, commonly referred to as a "moldboard", is properly and securely affixed to the front of the motor vehicle.
(Source: P.A. 85‑1010.)
(625 ILCS 5/12‑209) (from Ch. 95 1/2, par. 12‑209)
Sec. 12‑209. Additional Lighting Equipment.
(a) Any motor vehicle may be equipped with not more than 2 side cowl or fender lamps which shall emit an amber or white light without glare.
(b) Any motor vehicle may be equipped with not more than one running board courtesy lamp on each side thereof which shall emit a white or amber light without glare.
(c) Any motor vehicle may be equipped with one or more back‑up lamps either separately or in combination with other lamps; but any such back‑up lamp or lamps shall not be lighted when the motor vehicle is in forward motion.
(Source: P.A. 77‑37.)
(625 ILCS 5/12‑210) (from Ch. 95 1/2, par. 12‑210)
Sec. 12‑210. Use of head lamps and auxiliary driving lamps. (a) Whenever the driver of any vehicle equipped with an electric driving head lamp, driving head lamps, auxiliary driving lamp or auxiliary driving lamps is within 500 feet of another vehicle approaching from the opposite direction, the driver shall dim or drop such head lamp or head lamps and shall extinguish all auxiliary driving lamps.
(b) The driver of any vehicle equipped with an electric driving head lamp, head lamps, auxiliary driving lamp or auxiliary driving lamps shall dim or drop such head lamp or head lamps and shall extinguish all auxiliary driving lamps when there is another vehicle traveling in the same direction less than 300 feet to the front of him.
(c) No vehicle shall have the lighting system modified to allow more than 2 electric head lamps to be lighted while operating in the dimmed or dropped position.
(d) Nothing in this Section shall prohibit the use of auxiliary driving lamps, commonly referred to as "fog" lamps, when used in conjunction with head lamps, if such auxiliary driving lamps are adjusted and so aimed that the glaring rays are not projected into the eyes of drivers of oncoming vehicles.
(Source: P.A. 85‑1144.)
(625 ILCS 5/12‑211) (from Ch. 95 1/2, par. 12‑211)
Sec. 12‑211. Number of driving lamps required or permitted.
(a) At all times specified in Section 12‑201, at least 2 lighted driving lamps shall be displayed, one on each side of the front of every motor vehicle other than a motorcycle, except when such vehicle is parked subject to the regulations governing lights on parked vehicles.
(b) Whenever a motor vehicle equipped with driving lamps as herein required is also equipped with any auxiliary driving lamps or a spot lamp or any other lamp on the front thereof, not more than a total of 4 of any such lamps on the front of a vehicle shall be lighted at any one time when upon a highway.
(Source: P.A. 86‑1236.)
I hope this helps you
Old 02-20-2007, 09:33 AM
Sycostang67's Avatar
Sycostang67
Sycostang67 is offline
I have heard that any off-road lights located above the roof line need to be covered when the vehicle is on a public road. Bumper mounted lights are okay to leave uncovered. I have mine relayed to come on automatically when I turn on the high beams, so it would be a real pain to have to pull over and uncover them all the time.
Old 02-20-2007, 07:34 PM
bigbubba87's Avatar
bigbubba87
in the gallary search 1973 f250 4x4 and you will see a cammo truck with a coverd top on it i was wanting to put more lights on it but i live about an hour from quincy illinois and i get alot of parts there but dont wana get a ticket for having them uncovered on my truck can you drive during the day with em uncapped?
racin
1997 - 2003 F150
05-31-2016 09:00 PM
micheal1619
1999 to 2016 Super Duty
27
01-11-2016 07:06 PM
THEDON117
07-19-2015 11:32 PM
A/Ox4
19
05-07-2011 11:33 PM
93FordCTD
12-26-2008 03:37 AM
Quick Reply: off road/spot lights illegal in illinois
