Computer Help Needed
Old Feb 19, 2007 | 02:33 PM
taisa899's Avatar
taisa899
I'm running an AMD Sempron3000 with Windows XP Home Edition. My problem is that my DVD drive has disappeared. Doesn't show up under My Computer but yet when I put a CD into it, it spins and the read light comes on. When I go into the Device manager it tells me that it working properly. The DVD drive just isn't showing up and i really need to access it. Anybody got any ideas?
jim
Old Feb 19, 2007 | 02:37 PM
thefarelaneman's Avatar
thefarelaneman
Maybe your computer has lost its configuration settings for the DVD. You may need to use "system diagnostics" or even a system restore,,,,Use the troubleshooter instructions and check the default settings for the DVD. If the DVD is an add on run the software for it and see what happins first
Old Feb 19, 2007 | 03:13 PM
donjamer's Avatar
donjamer
Just delete it in device manager.Then reboot and it will find it again and automatically install.
If it still does not show up then it is a windows issue or some other program is interfering..
Old Feb 19, 2007 | 03:31 PM
furball69's Avatar
furball69
Go into Control Panel > Administrative Tools > Computer Management > Disk Management and make sure that the drive is still assigned a drive letter.
It should look as follows, or similar:
CD-ROM 0
DVD (E)
if there's no drive letter in parenthesis, then right click on it and select "change drive letter and paths" and assign a drive letter.
Old Feb 19, 2007 | 10:42 PM
thefarelaneman
furball sounds like a computer geek knowin all that stuff,,,,,,Im just an amature compaired to mr furball
Old Feb 19, 2007 | 10:58 PM
taisa899's Avatar
taisa899
there is a drive letter assigned to it. it just refuses to show up on my computer. In order to accesas the drive I have to go to Start>Run>Drive D:
Jim
Old Feb 19, 2007 | 11:13 PM
rusty70f100's Avatar
rusty70f100
Well that's weird. As a temporary workaround you could create a shortcut to D: and place it on your desktop. At least then you wouldn't have to go through the Start - Run thing every time.
I'd say start with a virus scan. It could be something goofy with Microsoft's wonderful operating system, but try the obvious first.
ddrumman2004
15
Dec 29, 2010 09:52 PM
Nitramjr
13
Feb 28, 2007 11:31 AM
z 97ford1
13
Jan 22, 2006 11:06 AM
Traxxis
Aug 5, 2005 08:45 PM
rshissler
Mar 16, 2005 11:32 PM
