1978 - 1996 Big Bronco
Body molding help - 93 Bronco XLT
Old 02-19-2007, 01:53 PM
darthkeebler's Avatar
darthkeebler
darthkeebler is offline
I recently had my 93 Bronco XLT repainted and body work done. As a result, the side body moldings had to be removed and could not be reused. I've searched a lot and cannot find aftermarket pieces. The dealer has these for around $400, but they are paint to match.
Does anyone here know of any place outside of the dealer to get these parts? On the XLT, these are the 3 piece moldings on each side, front, door, and rear panels, with a chrome strip in the middle. Any help would be appreciated.
Old 02-20-2007, 12:04 AM
ag30265's Avatar
ag30265
ag30265 is offline
Go to www.LMCtruck.com, search prt#-49-2679, it lists for $139.95 and they say it's ready to install. Order a catalog for your years models, lmc is one of our best friends around here.
Old 02-20-2007, 12:12 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Exclamation
Do the mouldings clip on? If so, just order new clips..why buy expensive mouldings if you don't need them. The pics in the moulding sections of the Ford parts books show all the clips for each moulding. The clips come in packages of 10 or so.
Do they glue on? Just buy some 3M double sided tape...that's what Ford uses to hold the mouldings on.
Anyone tells you mouldings can't be reused, is full of caca del toro. You can buy the correct clips from Ford, or 3m Tape from Home Depot.
Mouldings that are damaged are usually beyond repair.
Old 02-20-2007, 11:56 AM
darthkeebler
NumberDummy - it is the adhesive body molding, not the type that clips on. When it was removed it could not be reused.
ag30265 - that is *exactly* what I was looking for, you are the man! I am going to get a full catalog from the site. Thanks a bunch, I am going to order today.
Old 02-20-2007, 05:36 PM
lostin90s's Avatar
lostin90s
lostin90s is offline
Not a very good body shop .we reuse them all time.Cosidering some are $300.00 They must have pulled them off. Find some in wrecking yard use windshield removal wire ,heavy fishing line or even dental floss to cut the 3m tape don't pull on trim much.Can also use a heavy puddy knife but wire work better. Practice on bad piece first. Heat helps form back But on Bronco thats not easy to do. Good luck on search .
knucklecars
09-21-2016 12:12 PM
cumminpwr11
07-06-2015 11:48 PM
lrdvdr41
09-03-2013 10:07 PM
cpickner
1999 to 2016 Super Duty
05-16-2012 02:49 PM
Quick Reply: Body molding help - 93 Bronco XLT
