What oil should I use? - Ford Truck Enthusiasts Forums
Oil & Lubrication
Old 02-18-2007, 10:52 AM
newtattoobob1 newtattoobob1 is offline
newtattoobob1 is starting off with a positive reputation.
I have a 2005 F250 4x4 with the 5.4. I don't put many miles on, maybe 4,000 per year. When it is used it is in the winter for my short commute to work which is about 8 miles each way. In the summer when it is hot I pull my trailer which can weigh up to 10k. I have been using Motorcraft 5W20 syn-blend and Baldwin filters, and I am only changing the oil once a year. I am wondering if 5W20 is too thin when I am towing in the summer? Could I benefit from a full synthetic and different filter? Or should I stick with what I am using. Thanks Bob
Old 02-18-2007, 04:17 PM
ranger racer ranger racer is offline
ranger racer is starting off with a positive reputation.
I would use pennzoil platinum 5w20 with a motorcraft filter and continue to change it once a year
Old 02-18-2007, 04:23 PM
bigdaddyII's Avatar
bigdaddyII bigdaddyII is offline
bigdaddyII is a splendid one to beholdbigdaddyII is a splendid one to beholdbigdaddyII is a splendid one to beholdbigdaddyII is a splendid one to beholdbigdaddyII is a splendid one to beholdbigdaddyII is a splendid one to behold
I think you would be fine with the motorcraft oil, but I would use a motorcraft filter with it.
Old 02-18-2007, 06:59 PM
OSin86 OSin86 is offline
OSin86 is starting off with a positive reputation.
Honestly you're fine all around. To be 100% sure just pull a sample around 6 months and have a place like Blackstone take a look at it. In theory you have already picked a combo that should last just fine. At 4000 miles you really won't benefit much from a full synthetic.
Old 02-18-2007, 09:50 PM
firesoutmatt's Avatar
firesoutmatt firesoutmatt is offline
firesoutmatt is starting off with a positive reputation.
Look in your owners manual . It will tell you what viscosity and temp to use what fluid.
20 oil seems low for towing above 50 degrees F.
You have the 5w for winter.
I would be using a 30 or 40 for summer towing.
A good syn 5w40 should do just about right but check your manual.
Old 02-19-2007, 09:18 AM
pawpaw pawpaw is offline
pawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to behold
I know you don't put many miles on this ride, but it's the type of miles that you rightfully need to be concerned with.
Seeing as how it's sorta medium/short trip winter & some summer hot weather towing tossed in, imo that recipe meets the definition of "severe service", so consideration of a good synthetic lube with a strong add pack & high base number, isn't out of line at all. Sure isn't likely to hurt it!!!!
To be certain of whats going on though, why not have a UOA (Used Oil Analisis) done, as OSin86 has suggested, then you will know for sure how the lube & filter your now using, is holding up under your drive cycles.
Blackstone Labs is one of our site sponsers & has a good rep from the folks that have used their services.
I too like the current Motorcraft filter design & use it in all my Ford rides. It's a good value for the bucks spent.
If you have a UOA done, would be interesting to hear how it turns out.
Old 02-19-2007, 10:01 AM
rsylvstr rsylvstr is offline
rsylvstr has a great reputation on FTE.rsylvstr has a great reputation on FTE.rsylvstr has a great reputation on FTE.rsylvstr has a great reputation on FTE.rsylvstr has a great reputation on FTE.
I'd run the MC filter with MC blend...5W-30 if your manual calls for it....after two OCI's, then get a UOA and post it.
Baldwin Vs Motorcraft Fuel filter Kdr358 1999 - 2003 7.3L Power Stroke Diesel 7 04-02-2012 10:11 AM
Baldwin Filters??? morimoto_87 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 19 08-11-2010 10:46 PM
Hastings 'Densite' filters gezn2 Oil & Lubrication 11 02-26-2008 12:58 PM
More oil concerns brcowan Modular V10 (6.8l) 28 10-31-2003 03:20 PM
More oil concerns brcowan Oil & Lubrication 6 10-01-2003 11:20 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
