an alternative way to do IRS with Ford rear
#91
Ford IRS
Seems like the Thunderbird. Cougar, Mark VIII appear on craigslist.com in spurts. I decided on the Mark VIII. I thought maybe less chance on someone wearing out the rear end by dragging as in T-bird(I had a 97). The 1993 Mark VIII had a V-8. Early cougar and T-birds had V-6's and I couldn't find a good site on what years did what. Also the Mark VIII had air bags, etc. I could always find rear springs from a T-bird of cougar. I don't know if V-8 and V-6 used the same springs. The rear IRS cage mount might need a second cross frame member as I think the spring is going to give a lot of upward stress against a thin frame, maybe not, but I think I will add a extra cross member. Easy install and has sway bar. As for the front IFS the upper A-arm mount to be made is the trick. As others said waiting for experts do do one and show pictures. Have a great day,chuck
#92
When I first became acquainted to this forum I asked about putting the Super Coupe running gear under my 50 Panel and there wasn't anyone out there that had tried it. That was four years or more and now there are convertion kits for the IRS and hopefully someone is working on the IFS. If I didn't get side tracked by other projects maybe these suspensions would be under the truck and it would be rolling. Thanks for all the great input and patience.
Gear Up
Gear Up
#93
Can anyone tell me for sure. Do the 89-97 thunderbird, cougars, and mark VIIIs all have the 8.8" rear-ends? I thought this was the case but someone tried telling me today that the regular LX t-birds have a 7.5" rear-end and that only the Super Coups came with the 8.8". Does anyone know the real answer?
Thanks
Thanks
#97
pinion angle alignment
The short answer is to set the frame at the selected ride height, position the IRS subframe ( prior to welding the adapter brackets ). Bolt the subframe adapters to the subframe to position the subframe at the desired pinion angle, then weld the adapter brackets into place.
I use 6 or more angle finders located on the truck's frame, the subframe, etc... to assure proper positioning prior to ( and after ) welding.
Minor adjustments can be made with shims between the subframe and the adapters after the assembly is welded in place.
Full installation instructions are available showing this process.
dave
dave
#98
Converting Rear Drums to disc
The easiest way to convert from drum to disc is to replace the entire drum-style spindle with a disc-style spindle... spindle, rotor, caliper, etc...
The second option is to remove the drum, bearing, etc... and machine the drum-style spindle to mount the caliper. The machining involves drilling holes in the correct location to locate the caliper and machine the caliper mounting surface flat... The last step is to remove material from the spindle that would otherwise interfere with the caliper.
more info to follow immediately below...
dave
What type of brakes are available?
All Lincoln rear suspensions feature rear disc brakes. Some T -birds and Cougars have disc brakes, while others have drum brakes.
Either style of brakes will work... but disc brakes are preferred since they have greater stopping power.
I have a rear subframe from a T-bird with drum brakes... can I change the brakes from drum to disc brakes?
Yes, there are a couple of options. The first is to locate spindles with disc brakes, calipers and rotors... then remove and replace your drum brake spindles with the disc brake spindles.
They are interchangeable.
The second option is to modify the drum brake spindle to utilize a disc brake caliper and rotor. This is more difficult than simply swapping spindles, but it is possible.
Sounds like alot of work... why don't you just buy a subframe with disc brakes?
Agreed... buying a complete unit is the best option, but often there are only drum brake subframes in local wrecking yards... yet disc brake spindles are available all over the country. Since it is far easier ( and cheaper ) to ship a pair of spindles and brake components vs. an entire subframe - the option of buying a subframe locally and a pair of spindles through the mail is the best option.
dave
#100
IRS rear end
Originally Posted by CIAF
http://team321.com/truckirs/truckirs.html Seems like a lo cost way to put a Ford IRS in your ford. A buddy of mine is studying the kit and is looking for the Lincoln with bags from a lo miles car. His frame is bare and ready so it may get done soon. J
#102
Originally Posted by Mr. N
mytbtruck
Do you have any pictures of how you mounted the thunderbird front end in the truck?
#104
#105
Originally Posted by lumber jack
If this can be done with the Rear susp. Could you also do this with the front as well ?
Has anyone ever done or tried this?
