Electrical Problem
Old Feb 17, 2007 | 11:55 AM
Jack Brode's Avatar
Jack Brode
Cool Electrical Problem
I have a 1989 Ford chasis E-350 7.5 litre(460 F.I.) in my RV. I am having a problem with it shutting off and hesitating. It starts fine but when I drive it on a rough road it shuts off and it hesitates while driving sometimes. After driving for about 30 minutes and it was hot it started backfiring and completly shut off and would not start. After sitting for 30 minutes it started and I got it home but it was still acting the same. I have replaced the fuel filter, throttle position sensor, and coil pack so far. Could it be the ignition control module mounted on the distributor? If anyone can help or had this problem please let me know it will be greatly appreciated.
Old Feb 17, 2007 | 01:06 PM
Ultramagdan's Avatar
Ultramagdan
Hello and Welcome!
Sorry to hear about your problem. You will need to post your question in the tech forums since this one is only used for introductions and you want to reach the right people. Click on the Forums tab at the upper left and look over the choices. There are several forums that can help you out and you can try this one for starters: https://www.ford-trucks.com/forums/forum53/
Good luck and enjoy the site!
cajunjoey
New Member Introductions
Sep 23, 2007 05:56 PM
str8fancf
Mar 7, 2007 06:22 AM
johndeer68
Jan 22, 2007 06:57 AM
CRGIFT
Jan 8, 2007 07:26 PM
gtmashino
Dec 17, 2006 05:33 PM
