yeah, but i am sure the reserve is at least 12,500 or 13,000.
he just started the bidding at 5,000.
for $5000 i would go get it. the rebuilt rocks with discs are probably worth at least 3500
i will probably end up chopping the front down a little bit
cut out 7.5" and just use a short side shaft. those shafts are only about $225.
Discs are real expensive though. i think pinion brakes are just fine for me
how big a v-tread are you going to use?
